Drone for brushfire spotting?
   / Drone for brushfire spotting? #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
While at a large brush fire the other day I felt like I was tied up and blind. The brush and smoke was so thick that we could not drive or walk in it to get a look at the fire spread to extinguish it. The private roads were small and few. The fire jumped fence lines and roads. These are 1000 acre to 2500 acre continuous brush areas. We saw an airplane and was hoping it was a spotter plane from the TX Forest Service but it kept on going.
I was thinking today that a small drone would have helped tremendously to catch the small fires that were jumping out from the sides and head of the main fire. It would have also given us fast information of any structures, best areas of cutoff, how fast and where the fire was moving to help deploy the trucks.
There is one that I found some info on, but we might need one a bit more rugged than the Parrot AR Drone.
http://www.youtube.com/watch?v=fsJbQuEUrUg
I'm also thinking the wind might be a problem since all the bad fires happen when the wind gets above 20mph.
Does anyone have any experience with a small drone and know it's capabilities?
(We finally got it contained with the help of a couple of dozers and a bit of luck with the wind.)
   / Drone for brushfire spotting? #2
The March issue of National Geographic - the Magazine - has a well documented and illustrated report on "Drones". The story is at the last part of the issue. Very good reading.
   / Drone for brushfire spotting? #3
Dont know much about drones, only one I've seen in person was flying around the military base outside of Alamogordo NM last summer. I was surprised at how slow they can move.
I could see where it could benefit firefighters, but wonder about deployment time versus other means, then you have the quality of camera and monitor to consider to get the information that would actually benefit the fire crew..I'm thinking major $$
   / Drone for brushfire spotting? #4
Oh boy! The conspiracy theorists will be all over this. They'll say the government is setting fires just so they have an excuse to put them under surveillance. Of course it's wacky, but you just know it's gonna happen.:rolleyes:
Thanks groundcover that is exactly what I had in mind and they already make it. Of course the $50K is the deterrent now, but if they make them less expensive in the future and we can get one for the county or tri-county or with grant monies then it could be a possibility. I'll keep my eye on them and if anyone gets an opportunity to use one please report back.
   / Drone for brushfire spotting? #8
My concern would be that a drone would not be deployed by any of the first in engines; it would be after an incident command was set up.
   / Drone for brushfire spotting? #9
Hiya
Have a look here: DIY Drones
Drones like the arducopter will lift a good camera easily. Also search on youtube for arducopter for nice examples of the video one can get. It would be excellent for fire spotting and checking fence lines, weeds etc. [Also lots of people should get them so that when the govt wakes up that they don't want people to have them by that time nearly everyone will know someone that has one for a good purpose - even if just for fun.]
Mike
   / Drone for brushfire spotting? #10
My only worry with a small drone would be that it couldn't handle the updrafts from the fire...
Aaron Z
Robert, With the distance in-between station out here and the cost of a drone there will be a launch by command hopefully within 30 minutes of first arrival fire trucks. So training and observational experience will still be vital. If the fire is too small or too large (like the Bastrop fire, thousands of acres, winds 50 mph) the drone would not be launched. It would be perfect for the 5 to 500 acre acre fires in thick brush.
Mike, that site is interesting I will have to investigate it more, thanks. It looks like they could answer a lot of my questions about wind.
Aaron, the winds that the fire creates, as I see it, would be the biggest problem. I hope some FD figures out if drone spotting is feasible or a waste of resources.
   / Drone for brushfire spotting? #12
   / Drone for brushfire spotting? #13
camera is going to play roll in overall weight. a larger unit, with bigger engine and fuel supply, would better offset camera weight.
trying to get a small little unit to fly any sort of distance..... plus place to land, etc... let alone place to take off.
if government has these high priced dollar drones already, why not just "rent" per say. county or state gov, renting from fed / military. to allow drones to be ran through given areas.
ya wanting to pin point the fire line i would assume, and then anything within possible nearby path/s of fire (accounting for wind). that could feed the fire.
get a military drone setup, to take pictures of areas that may be hot spots. and as needed, allow fire department head quarters to get images off of the drone.
as much as i dislike idea of some drone or plane or helicopter taking pictures, say day or 2 before a fire, to help identify possibly problem spots for fires, or prep work for in case a fire happens. and these pictures / video. taking real time video / pictures with folks consent, but really. for a township, to county, to a state, or specific coordinates on a map, to give areas. that are more likely prone areas for fires. *shrugs*
seriously, get some contract going, so fire fighters, could punch in some GPS coordinates. and pull pictures off of some computer database. and display things on a screen right in the truck. heck "google maps" and turn to what is it "earth view" but setup for what ever is needed for more real time pictures that were recently taken.
   / Drone for brushfire spotting? #14
I have a DJI Innovations Phantom which has a pretty decent range and I use it with a camera to take aerial video and photos. I haven't tried it in any winds more than say 10 mph. Heavy winds would certainly eat in to flight time and make landings tricky. There are a number of video systems that allow you to get a live video feed from the drone.
This is the drone:
Phantom Drone Quadcopter
Here are some videos I've shot just piddling around with it:
https://www.youtube.com/watch?v=diYqNiTEH2I
https://www.youtube.com/watch?v=rRfmCQljPyM
https://www.youtube.com/watch?v=6ZHGeTkeKos
Here is an example from a FPV system on a Phantom where the guy flew it 1.4km away.
https://www.youtube.com/watch?v=E6ekn29NYrE
   / Drone for brushfire spotting? #15
Small relatively inexpensive drones are worthless for this situation, at best you could watch the fire spread from above. You would be dollars ahead to have your local fire department standby with a tanker truck. I assume from reading your posts that you are in a relatively remote area. RC type drones take a lot of input to fly and trying to view a video while manipulating the drone would result in the drone crashing and possibly creating its own fire from fuel on a hot engine. Battery operated craft take too much power with current technology to be of any use, the flight time is too short even with lithium ion power packs. I am getting ready to burn a debris pile that I have created. We have no burn ordinances from 6 AM until 6 PM and we are required to notify the county fire department prior to the burn so if they receive a call about the smoke. I keep a cell phone with me and the FD (not 911) on speed dial so I can call them if it starts getting out of hand. The intent here is to call them prior to it becoming an emergency situation.
KYDan, I am the local VFD and we got called out after it got out of control. This was a brush fire that was thought to be out two weeks earlier. I have a problem with anyone wanting to call the VFD to standby while they burn. If the land owner has any thought that it might get out of control they should not burn. If the VFD is standing by they are taking all the liability. I do not volunteer my services to put myself liable. They do have people who are heavily insured to do control burns they are not VFDs.
   / Drone for brushfire spotting? #17
The volunteer fire departments here are mostly special districts and a defacto unit of local government which shields them from most liability aside from gross negligence. I don't know anything about Texas statutes, therefore, I can't really comment on the liability there. I am a pilot and I do fly RC's so I have some knowledge of the worthlessness of commercially available drones for an application such as this. You might want to check with an attorney about a liability waiver in these situations. And yes, patience and waiting for the optimal time to burn brush is the best recourse, but there is always a chance of a fire getting out of control even then. It is hard to imagine that a state would not limit the liability of a volunteer public servant in these situations.
Our VFD was started by private donations 20 years ago and is still operating with donations. The local Government has no control or say in anything we do and we have no shields from them that I know of. I'm sure the owner would sign the liability waiver but would his neighbors? I agree with you the safest burn would be to have a truck stand by by at each burn. But then we would have to buy liability insurance and with the number of burns out here we would have to pay someone to stay for hours while the logs burned. I just got back from a structure fire, mutual aid, we had a total of 2 firefighters from our station, me being one. That's 3 fire calls in nine days. On the way to the structural fire we passed three brush pile fires.
Even if we were protected by the state, and I don't think we would be if we started the fire or assisted in any way, I would question any request to babysit a control burn. Basically - That's not our job and I can not depend on the government for any shielding.
   / Drone for brushfire spotting? #19
You do realize that drones that are flown more than a rocks throw away from the controller are done so using video links and/or pre-programmed flight paths using GPS?
Now it is true that the cheap quadcopter type drones such as my Phantom are only good for 15-20 minutes of flight time depending on configuration but more serious drones like the RQ-11 Raven (battery powered) are capable of more than an hour of flight. We fly a lot of drones out here at White Sands Missile Range and they are much better than you think they are.
   / Drone for brushfire spotting? #20
Here is a video interview with the DJI Innovations guy where they talk about the Australian Fire Dept. using the Phantoms to check out burn areas. The link is cued to the relevant section.
DJI Phantom - YouTube
1762 (A58375)
1762 (A58375)
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2019 KOMATSU PC490LC-11 EXCAVATOR (A60429)
2019 KOMATSU...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
Kubota RTV X900 (A53317)
Kubota RTV X900...
