driveshaft sources/parts
   / driveshaft sources/parts #1
Dale1995
Caribou,Maine
John Deere 2320
I am going to try to modify the front driveshaft that powers my 47" snowblower,on my 2350 john deere. I am looking for sources for small cv joints and various driveshaft stubs so I can manufacture a better driveshaft, any ideas or websites might help:D
   / driveshaft sources/parts #2
I would look at a local machine shop, ours has a machine to test drive all the drive lines they build. They have sources for almost any setup and u-joint. Your local one might also.
I had a new rear drive shaft built for a full size diesel that had problems keeping u-joints, after they built one up never had to mess with it again. Drove that truck 250,000 miles before we traded it in.
   / driveshaft sources/parts #3
Many ATVs with 4wd have true CV (constatnt velocity) joints up front. I don't mean common Cardan joints, but Tripods. I'm not sure what max angle they will run up to. You can make an approx. cv joint from a pair of Cardans. Just looks at a truck driveshaft to see the double Cardan worked as a CV joint.
   / driveshaft sources/parts #4
Here's one good source of drive shaft adapters, slip-on and weld-on:
Hub City Inc
   / driveshaft sources/parts #5
You might also try Inland Truck- they have driveshaft ends, make up drivelines...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
Polaris ATV (A50324)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
TMA (A49461)
TMA (A49461)
