Driveline Noise
   / Driveline Noise #1
Bill_Calif
My B5100 has a driveline noise that seems to come from the front drive shaft. I have had this problem before in which the front drive shaft tube and rubber dust boot were slipping. This is the same noise I had previously, but the problem does not appear to be a slipping driveshaft tube. Any ideas out there?
   / Driveline Noise #2
Bill,
Can you describe the noise? Grinding? Rattling? Knocking?
Maybe this will help people think of something...
Bob
Bob Trevithick
   / Driveline Noise #3
Bill:
Is everything tight on the driveshaft like u joints and are all the seals in place? Is there oil in the diff.?
Can you lift up the front and hear anything by turning things by hand?
Egon
   / Driveline Noise #4
We have noticed loud squealing noises from front drive B5100/B6100/B7100 models. Typically,the noise stems from a plastic bush which guides the inner end of the drive shaft to the front diff. The bush dries out and the resulting sound is a fierce squeal.
The fix is to lubricate the bush and shaft.We just force some grease between the shaft and bush.Access is through the hollow centre tunnel. You may need to loosen rubber hose which connects the drive shaft tube to allow the tube to slide back a bit, and up along the shaft. Normally we can fix them without dismantling the front drive.WD 40 spray also fixes it,but dries out fairly quickly.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2008 Mazda CX9 SUV (A50324)
2008 Mazda CX9 SUV...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
