Mowing Drive over mower decks for 3000 series
   / Drive over mower decks for 3000 series #2
Well if they would have had these available for order about 5 months ago, I probably would have purchased one. They must be a lot heavier than the original 7 iron. they also cost a bit more. The cost for plastic ramps is a lot less! :D
72D AutoConnect 7-Iron Mid-Mount Side Discharge Mower
(For 3120-3720, 4310-4410 Tractors)
3120-3720 Tractors Require Mid PTO. Mower Deck is Not Compatible with R3 Turf Special or R1 Tires, See Sales Manual for Tire/Mower Clearance Chart. LVB25820 is Required for Use with LVB24815 Front Three-Point Hitch with A-Frame (3120-3720 Tractors Only) and Mid-Mount Mowers. For Installation of Mid-Mount Mower on Cab Tractor, Must Order (1) LVA14927, (3) 19M7785 , (1) 19M7788, (1) LVA15373 and (1) 34H311 Through Service Parts. See Sales Manual for 4310-4410 Requirements.
7020LV ````````````````````````````````````````````````````````````````````````````````````````````````$3,920.00
AUTOCONNECT MOWER LIFT
AutoConnect Mower Lift (3120-3720, 4310-4410)
Includes Mid Hydraulic Cylinder Lift Kit.
   / Drive over mower decks for 3000 series #3
WOW.. what a price.. I think my 62d (for a 2320) was in the $2400 range... But that is quite a jump in price..
BUT the drive over deck is very, very nice.. Its so easy to install the mower
Brian
   / Drive over mower decks for 3000 series #4
For a few K more you could get a zero turn with the 7 iron deck.
   / Drive over mower decks for 3000 series #5
I even saw a couple of used 777's on sale for around the same price with only 300 hours on them. Somebody got them, quick.
This deck would also have to work with my Turf Specials, and it seems it is spec'ed for R3 and R4's but the 7 iron deck is not spec'ed for my Turf Specials and they sure work on my unit without any issues.
   / Drive over mower decks for 3000 series #6
Its still another item to go on and off the tractor everytime you really want to use it....:(
   / Drive over mower decks for 3000 series #7
My 62D is a breeze to take on/off - BUT im sure these will be bigger/heavier.. Tops it takes 5 min on/off, but just getting the PTO attached can take longer than that at times.. LOL
If i need the mmm off for just a short time use, I drop it in the yard and do what I need. Then hook back up before I head back into the garage.. for longer storage I made a set of axles so it stands upright and out of the way..
Brian
   / Drive over mower decks for 3000 series #8
The reason I made that statement is because my tractor is in the field almost everyday. I could not have a MMM on when doing thos tasks. So I would have to put it on each time I needed to mow. Not something I want to do, and for the price, I do not want to pay for it either.
   / Drive over mower decks for 3000 series #9
The price is about twice what i paid for my MMM used in perfect shape.
Plus like Thatguy said, that deck has got to be heavier than the already heavy 7 iron deck!:eek:
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
2000 FRHT FL79 (A50323)
2000 FRHT FL79...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
2013 Ford F-550 Ambulance (A50323)
2013 Ford F-550...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
