Drive Belt is slipping.
   / Drive Belt is slipping. #1
TenOC
Burns TN
Club Cadet Z Turn 53AA5B7P710
I am a new to the Forum. I searched for a answer without any luck.
1. The v-belt (item 8 01008349) on my 53AA5B7P710 Z series that drive the wheels - not the mower blades - is loose. I can not find out how to reinstall it or to see if the tensor is bad. Do I need to remove the complete drive deck to get to these items?
2. At the rear of the unit I discovered two rods (one on each side) I think they are called "pump rods". The rods are bent at right angles and looks like one can pull them out an there is a round locking ring to lock them pulled out. What are they for??? . . :confused:
   / Drive Belt is slipping. #2
1) prolly will need to remove deck for visibility/access. Check function of drive belt idler brkt/pulley/spring for proper drive belt tensioning.
2) look on Pp 21 or 22 of yer owner's manual - should see pix describing same. they disengage hydros for freewheeling pushing. suggest becoming familiar with manual contents.
2019 Cat D5K2 LGP Dozer (RIDE AND DRIVE) (A50774)
2019 Cat D5K2 LGP...
2020 KUBOTA RTV...
2016 Komatsu PC1250LC-8 Hydraulic Excavator (A50322)
2016 Komatsu...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
