Drive belt for Rear Mount Mower
   / Drive belt for Rear Mount Mower #1
Hook
Bronze Member
Milford, NJ
Kubota L3010
I have a Lande Pride 72" rear mount finishing mower (FDR2572). last night, the drive belt jumped off the pulleys. So I took off the covers to accesd the belt & pulleys & got out my owner's manual.
But I have 2 problems:
1) The manual covers 3 model of mower: 60", 72" & 84". It looks to me like there is a mistake in the drawings, however. My puuley arrangment seems to match the drawing for the 60" mower, not the 72" mower.
Can anyone with a FDR2572 mower confirm this (of course, it could be for a specific year)?
2) What is the secret for getting the adjustable puylley back to here it shoyuld eb once you get the belt installed on all of the pulleys?
I tried many different ways, but I just can't push this pulley far enough to get it back to where it should be.
Any thoughts?
Hook
   / Drive belt for Rear Mount Mower #2
I assume you mean you are having problems stretching the belt over the pulleys?
One of the pulleys should have a threaded rod or spring to adjust the tension. Mark where the it started with a paint pen or magic marker and loosten it all the way. After you get he belt over the pullyes retension the one you adjusted.
I have the 2584 mower and I will check my manual and see what it says. This mower was bought last year so it may not apply to yours but I will check anyway.
JT
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
2018 Hino 155 16FT Cab and Chassis Truck (A51692)
2018 Hino 155 16FT...
Kubota BX2230D (A47384)
Kubota BX2230D...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
