Drip from fuel tank on C/IH 574
   / Drip from fuel tank on C/IH 574 #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
I have found a small drip on the back of the left edge of my fuel tank. It is the saddle type tank with a flange bolted to the fenders and it appears to have a gasket fitted in between the flange and the fender. I have down-loaded the parts diagram from Messicks, (very helpful). The service manual does not discuss this. Has anyone taken a tank off of this type of tractor before? Any insight regarding hints, tricks, what to watch out for would be appreciated. Thanks in advance for whatever help is provided.
   / Drip from fuel tank on C/IH 574 #2
A drip from that area usually means the tank is corrodedon the end panel against the fender, it is a moisture trap area, and we know steel loves moisture??.
Remove the tank and carry out repairs, a welded repair is best. Whilst the tank is off it should be cleaned out, then washed out with something like PQR marine clean, you may need to get a pressure washer lance inside or a steam vcleaner to get it really clean and get rid of the crud !!
Then treat with PQR metal treatment to remove internal rust, clean and dry off then apply a coating of PQR tank preserverto the inside, once this sets it will seal up any small rust prforations and the tank will be like new!!
Its a shity job but is the only wat to stop rusting of a steel tank!!
Thank You. I now have the tank off and I am sending it out to a local shop for re-furb. Found a real mess on the end panels, also many wires and hose/tubes in dis-repair. I am sure the previous owners did what was needed to get/keep it running. I do not intend on making this a show piece so will fix what I can, when I can.
Electric Scissor Lift (A50322)
Electric Scissor...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2012 WESTERN STAR 4900 SB (A50854)
2012 WESTERN STAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2017 PETERBILT 567 (A50854)
2017 PETERBILT 567...
