Drilling and tapping a grade 5 bolt
   / Drilling and tapping a grade 5 bolt #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
I have a project that requires a 3/4-16 bolt. I need to drill and tap a hole in the center of the head for a 5/16 bolt to go into. I only need one. I can't find anyone who has a grade 2 in stock. Most said they couldn't get one and one said he might but if so I would have to buy the whole box (understandable). But a grade 5 version of the bolt I can get. I have drilled G5 without problems but I've never tried to tap threads into one.
   / Drilling and tapping a grade 5 bolt #2
It should be fine, just go slow and back out the tap to clear the flutes often, and use good cutting oil. I'd drill the F hole in the lathe so it was dead center and straight, but would tap it by hand.
   / Drilling and tapping a grade 5 bolt #3
Use a good tap and cutting oil and you'll be fine.
   / Drilling and tapping a grade 5 bolt #4
I'm not sure what hardness a grade 5 bolt is but I wouldn't hesitate to drill and tap it. But I would do it in a lathe so I had better control of the feed and such. Use plenty of lube on the drill and tap, tap magic comes to mind. Unless you are needing a really tight fit on the 5/16" bolt, drill the hole a few thousandths over size before tapping which will help take some of the pressure off the tap.
A 5/16"-18 thread recommended drill hole is an F drill, .257 dia. The next size drill is a G drill, .261 dia. which is what I would start out with.
A 5/16"-24 thread recommended drill hole is an I drill, .272 dia. The next size drill is a J drill, .277 dia which is what I would start out with.
After you drill the hole, make sure to chamfer the hole to help the tap start straight. Use the lathe to get the tap in a few threads then tap by hand to get the depth of thread you want. I assume it is a blind hole so remove the tap every few threads and clean out the shavings so you don't bottom out the tap and break it.
Lube, Lube, Lube.
   / Drilling and tapping a grade 5 bolt #5
I did just that with a 1/2" g5 bolt and a 1/4" bolt into it. I didn't allow enough room to get an full thread bolt in where it had to go, by cutting the thread off and drilling and tapping the end I was able to get it into place and used the 1/4" bolt to hold it. Did it with a drill press and hand tap so it's not hard to do ......Mike
I didn't think it would be and the worst case would be to break off the tap and throwing it away but thought I would ask. I can drill the hole using my wood lathe but not to tap it. That I can do on my drill press. The lathe will center the hole perfectly.
   / Drilling and tapping a grade 5 bolt #7
If you know how to use a tap and drill it shouldn’t be a problem. A drill press would be better, lathe better yet but by no means a necessity.
   / Drilling and tapping a grade 5 bolt #8
IMHO there should be no problems, a 3/4" Bolt is meaty.
Use a drill press to drill the hole, make sure you keep the bolt straight.
How I would do secure the bolt for both drilling and tapping, is use two Nuts on the bolt and secure it in a Drill Press Vice.
Once the hole is drilled, tap the bolt slowly, by hand, in one turn out one half turn, in one turn or two, out a half turn and so on and so on !
Use a good quality cutting/tapping oil, it will make all the difference in the world. Dependent on how deep you are going, they even have oil for deep tapping... what is the difference, I do not know !
The grade 5 bolts are harder than grade two and not as hard as grade 8, but very workable, shouldn't cause you a lot of grief, just take your time !
I have drilled a three inch, grade five bolt, almost all the way through, cross drill it, and tapped the head end for a grease fitting, I used it for greasing inside of a Spring bushing. I've also drilled all the way through a one quarter inch bolt, two inch long to make a small sand blaster gun..., so it can be done. I use a high speed drills and turn up the Drill Press Speed, and drill SLOWLY.
Keep the drill sharp and lubricated. Less walking with a sharp drill.
That my two cents... good luck on the project.
Ltr
   / Drilling and tapping a grade 5 bolt #9
Grade 5 is just a normal every day grade of bolt. The hardness dosnt really come into play here. Gr5 being normal is why you had to buy a whole box of gr2, no one wants them.
   / Drilling and tapping a grade 5 bolt #10
Grade 5 bolts drill and tap fine.
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2008 Honda Civic Sedan (A48082)
2008 Honda Civic...
2023 Ford Explorer AWD SUV (A48082)
2023 Ford Explorer...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2010 Toyota Camry Sedan (A48082)
2010 Toyota Camry...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
