Drilling a well?
   / Drilling a well? #1
dummy
Platinum Member
Southern Maryland
Ford 1220, John Deere 770, Case 580E and Allmand TLB-35
I need to replace a hand-dug shallow well with something a little deeper (30-50 feet) to irrigate a wildlife garden. Short of getting all the permits and calling out a drilling company, any ideas? I considered extension rods for my PHD, but am concerned with the torque effects.
   / Drilling a well? #2
Got rocks? If not, you might consider just getting a drill point, pipe and put in a good workout with a sledge for such a shallow well.
   / Drilling a well?
"Got rocks?"
Only in the head according to wife. Didn't realize you all knew her! Actually, lots and lots of hard,red clay then into sodium bentonite, then a gravel layer. Not impossible, but I think drilling would be easier. Just looking for an inexpensive way out.
   / Drilling a well? #4
Here's some instructions for a <A target="_blank" HREF=http://weather.nmsu.edu/hydrology/wellpoint2.htm>driven well</A>. It does sound like a lot of work /w3tcompact/icons/smile.gif
   / Drilling a well? #5
Just pounded one to 25 feet for irrigation. After busting several pounding caps and wrecking a lot of threads, found that a post pounder, the kind that you find at you local home improvement store made out of pipe with the built in weight works the best. Did it in one afternoon.
   / Drilling a well? #6
Dumbdog did it the same way I did, almost. Before I had my tractor I tried my hand at putting in a shallow well. I used a twist type human-powered post hole digger. I kept adding pieces of pipe untill I dug down to about 12 feet. I then got a well-point (sand-point) and some pipe. I drove it down to about 27 feet with a human-powered post pounder. It was'nt that difficult, it just took time. Oh yeah, I never did hit any water. /w3tcompact/icons/frown.gif
   / Drilling a well?
The no water scenario does make life worse. Dug a 12' deep hole last night with the backhoe and hit water, but I can pump it dry in 2 1/2 minutes. That's why I would like to go deeper and a little larger in diameter.
   / Drilling a well? #8
yep, same here. You can dig a hole 3 ft deep anywhere on my property and hit water. So, I thought if I went deeper I would find a good flowing source. No luck.
   / Drilling a well?
Neat moniker. Just checked your bio. and still find it hard to believe people choose to live in ND. Know people in Bismarck and Fargo. Made a huge mistake by stopping for a visit in February one year. Now I know, for me, if I can't go between July 1 and 15 then I stay home.
Allied 760 Loader (A50515)
Allied 760 Loader...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
10x16.5 Tire Assembly (A52128)
10x16.5 Tire...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
