Drill Start Mower
   / Drill Start Mower #1
MoKelly
Super Member
Jefferson County, Mo, ... about 35 miles out of St
Bobcat CT235, Bad Boy z-turn, Suzuki Vinson 500 and F-150
Tell me if I am crazy but I want to begin starting my pull behind mower with a drill.
I have had lots of problems with the pull start ... from broken ropes, broken springs, broken pawls, etc., etc., etc. It just isn't working properly.
Here is my problem. The engine is a Briggs 12.5 HP on an Agri-Fab pull behind. My current cordless drill (18 volt Makita) isn't quite strong enough to turn the engine over. Almost but not quite.
So, my question is whether anyone can recommend a drill powerful enough to turn the engine (corded or cordless) and whether this is a bad idea (pull my arm out?). I've used drills on regular push mowers but this engine is much bigger than those engines.
Any help is appreciated.
MoKelly
   / Drill Start Mower #2
I used to use a drill on a 11 hp b&s engine on a JD 111. The electrics were fried on the tractor and when the battery would go dead and it didn't work to roll start it I used the drill. I was only able to use a corded drill cause the cordless didn't have enough power. I think it was a Milwaukee drill dad used for mixing mortar and drilling concrete. It had plenty of power.
Make sure the drill is turning the same direction as the motor and use a connection from the drill to the motor so when the motor starts it pops the drill off.
*Do at your own risk and if you are not sure, don't do it.
2007 KENWORTH W900 MIXER TRUCK (A45046)
2007 KENWORTH W900...
2015 Ford F-350 Pickup Truck (A42744)
2015 Ford F-350...
2014 Ford F-250 XLT 4WD - 6.2L Gas - Ready to Go to Work (A44789)
2014 Ford F-250...
2019 6105E John Deere 2WD Cab 105HP Tractor (A44789)
2019 6105E John...
John Deere Z375R (A44502)
John Deere Z375R...
2014 Nissan Quest Minivan (A42744)
2014 Nissan Quest...
