Draw pins
   / Draw pins #1
Musky50
Grayson
1990 Ford 1720 and 2006 MF 1533
Can I install draw pins on the back of my tractor to attach and detach 3 point hitch bars faster? I have backhoe attachment and need to remove the 3 point hitch when I use it. I didn't know if they would allow to much movement and damage anything?
   / Draw pins #2
The attachment for 3 point arms I've seen are a rod that goes through two holes in the rear casting. Using two individual pins would really concern me that the casting could be stressed and broken. Picture a two wheel cart with a straight axle that spans the cart to connect the wheels versus two wheels that bolt on individually to each side.
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
1000 Gallon Fuel Tank W/Pump (A50774)
1000 Gallon Fuel...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2015 CASE 850M WT CRAWLER DOZER (A51242)
2015 CASE 850M WT...
CATERPILLAR D6R XL CRAWLER DOZER (A51406)
CATERPILLAR D6R XL...
