Drain tube came loose from crank case.
   / Drain tube came loose from crank case. #1
Vigilant
Bronze Member
Instead of the cap coming off the end of the oil drain tube, the tube and cap are now coming loose from the crank case. This is on a John Deere GT275. Can the tube be welded to the crank case? Thanks.
   / Drain tube came loose from crank case. #2
Might be one of the very few times I'd look at JB Weld so it can be removed easily. Too bad you can't have the tube knurled so it will stay in. Is that what they do or are they just pressed in? I had a car that did the same and JB worked.
8ft Perforated Metal (A51573)
8ft Perforated...
2023 Chevrolet Express 2500 Cargo Van (A51692)
2023 Chevrolet...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2012 DODGE DURANGO SUV (A52576)
2012 DODGE DURANGO...
