Drain plug for radiator?? Shibaura 1400
   / Drain plug for radiator?? Shibaura 1400 #1
PAT1
LOUDON TN
Ford 1500, Shibaura,Case, Gravely,Snappin` Turtle
I just got the broken drain plug out of the radiator on my Shibaura 14/1400
It is plastic and doesn`t seem to be a 1/4 or 1/8 pipe thread. One is too big and one too small.
Reckon it is something unique (oddball) to Shibaura.....it is a Showa brand radiator ??
Help
   / Drain plug for radiator?? Shibaura 1400 #2
If you can't get the replacement I'll bet that an auto parts store might have an expandable rubber plug that would work for you....just a thought
turns out it is a 12mm x1.75 bolt pattern. a flat washer and some rubber washers should do the trick.
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
