Dragging Up and Old Post ( Coolant Leak )
   / Dragging Up and Old Post ( Coolant Leak ) #1
tc35dforme
Platinum Member
New England...Central MA
TC35D/16LA
Well, I've got it. After nearly 300 hours, I've got the coolant leak at the fitting next to the oil filter. My problem...I remember reading that you need a modified socket ( slotted ) to get over the nipple for the hose and then spin off the part. I've tried searching for info and can't seem to find it.
Anyone that has done a repair, can you please post some pointers as to the socket details, or at least a link to the posts that detail.
Since the leak is VERY minor, I'll just re-install the OEM part after cleasning and the application of some good thread sealing goop. It doesn't look like any was applied at the factory.
   / Dragging Up and Old Post ( Coolant Leak ) #2
I had this problem on my 1998 NH 1925 last fall. The replacement threaded fitting was around $7 I believe, so I replaced it. The old one was corroded. I used a crow foot wrench...and the size is just over one inch.. maybe 1 1/16. I found that these wrenches a hard to find, the rental shops don't have them, Sears went up to only one inch, so I bought a cheap set at Northern for about $40.
After I replaced the fitting using a good measure of pipe dope, I still had a small leak, so I added a bars leak tablet to the new 50/50 antifreeze mixture. So far this spring, it appears to be holding.
FAKE (A52472)
FAKE (A52472)
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
2002 John Deere 5220 (A50120)
2002 John Deere...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2016 GMC Sierra 1500 SLT 4x4 Crew Cab Pickup Truck (A50323)
2016 GMC Sierra...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
