Dragging Trees
   / Dragging Trees #1
FarmerFrank
Seattle, Washington
Kobota BX2200
I am obviously new at this. How would one go about dragging large fir trees out of a forest with a small BX2200. Would I use a chain or cable? How would I attach it to my BX? How would I attach it to the tree? I can cut the trees up if they are too heavy but still do not know what to use or how to use it. Are there any good books on tractoring and using implements? -- Thanks Frank
   / Dragging Trees #2
Let me see if I got this straight... You want to pull your BX with a large Fir tree.../w3tcompact/icons/blush.gif
First, anything you want to tow... hookup only to the drawbar... {you don't want to upset the your tractor's center of gravity}
Can you imagine towing one of those large fir's on a grade... and it starts slipping away down the grade... guess who's heavier... guess who the boss is... guess what will happen? /w3tcompact/icons/frown.gif that's called the tail wagging the dog...
What is the maximum tow capacity of the BX? Then figure out how much of a log and how big... I think you'll be surprised.
"You are what you eat, drink, think, say and do..."
   / Dragging Trees
John,
Thank you for the advice, especially the safety warnings. The max load on the BX2200 drawbar is 550lbs. That's probably about a 5' section. No grade luckily, I would hate to get wagged.
For comparison I wonder what the drawbar load limits are for the JD 4100 and the NH TC21D.
Frank Dwyer
   / Dragging Trees #4
   / Dragging Trees #5
I've done this three ways with varying levels of success.
The best is to use a logging winch, but I think the BX is to small for that.
I've also hooked chains to logs and pulled them with the draw bar. Heed the warnings about only using the draw bar to prevent backflips.
Last is to cut the logs in to 4' to 5' length so they fit in the loader and haul them that way.
I've settled in to using the winch anywhere I can scuff up the ground surface, and cutting logs for the loader where I can't trash the ground like in the yard.
   / Dragging Trees #7
What you need there Frank is a logging arch, or a big wheel rig like this...
I couldn't find it, but I do recall seeing a logging arch made for our smaller tractors. Similar to the big wheel concept except you can use smaller wheels with the arched axle.
Basically, either contraption is used to lift the front of the log. That makes it easier to pull since it won't dig in. I don't know how much horsepower you've got, but the one in this picture only needs two /w3tcompact/icons/smile.gif
   / Dragging Trees #9
And an even bigger one ...
Patrick
   / Dragging Trees #10
Yeah, that's the one. Good find Crowes. I looked at one of these but the property we ended up buying is mostly open so I didn't need it /w3tcompact/icons/smile.gif
2014 CATERPILLAR 272D XHP WHEELED SKID STEER (A51242)
2014 CATERPILLAR...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
