3-Point Hitch Draft control
   / Draft control #1
sgipson
south mississippi
ford 3600 1974
I have an M5040 with FEL. When using a boxblade and pushing trash in reverse the lift arms will move up when pressure is applied leaving pieces behind. Is this a draft setting problem or what? I have tried the draft control lever up and down with no changes. It also seems to be more sensitive when in forward pulling trash etc.
   / Draft control #2
3 Ph does not have down pressure... it floats
try extending your top link... and maybe add some weight to the box blade
Draft has nothing to do with it
   / Draft control #3
I think what you mean is "position control" ..it allows you to set the level of the 3ph but it as mentioned it is still going to float...the position lever lets you hold it up anywhere between all the way up and all the way down...
2008 Chevrolet Colorado Ext. Cab 4x4 Pickup Truck (A48081)
2008 Chevrolet...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2014 Mazda Mazda3 Sedan (A48082)
2014 Mazda Mazda3...
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
2010 Ford F-250 Ext. Cab Pickup Truck (A48081)
2010 Ford F-250...
2010 Jayco Jay Series 1206 15ft S/A Pop Up Camper (A48082)
2010 Jayco Jay...
