draft control on mf 1135
   / draft control on mf 1135 #1
jamstew2002
volant pa
MF 1135
Do I need to hook up the top link on a 5 bottom simi mount plow to set the draft control and how do I do it.
Thanks Jim
   / draft control on mf 1135 #2
The draft control on the 1135 works off of the toplink. It has to be connected for it to work. I had an 1155 and never was happy with the draft control on it. I finally took the draft spring plates off and welded up the toplink pin boss where it couldnt move.
   / draft control on mf 1135 #3
As tated the top link needs to be connected. My 135 wasn't working right until I took the top cover off and rigged it correctly, it was obvious someone had tried before and either gave up or was reading the clearances all wrong. Now that it's back together it works well.
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
SAND BLASTING CABINET (A53843)
SAND BLASTING...
