DR POWER GRADER
   / DR POWER GRADER #1
Hughgdsr
Heflin,al
Bobcat
DR POWER GRADER WON'T RAISE/LOWER WITH KEY FOB,CAN'T FIND INFO ON HOW TO TEST. ANY HELP APPRECIATED.
   / DR POWER GRADER #2
easy on the caps please. it be like yelling on internet. and hurts my eyes when it is all caps.
check *fuse*.
check your *connection plug* to unit and pulling vehicle to see if corroded (di-electric grease) get from all automotive stores, and normally large hardware stores.
*multi meter* to check to see if you are getting 12V back to unit. (electronic stores to large hardware stores, to automotive stores) normally have these any were form cheap 15 to more expensive 50 plus units, cheap most likely good enough.
if you have a wireless remote, check battery in the remote. possibly replace batterie/s in remote.
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
