DR Power Grader and 2305
   / DR Power Grader and 2305 #1
absrio
Bronze Member
Stop Light City, IN
I ordered a 60" DR Power Grader back in April to try out and to see if it really worked. They had a sale price, free shipping, extended warranty, and 1 year trial. I figured I could get some work out of in a year and not be out to awful much if it didn't work.
My driveway is 200 yards long and had very little rock on top, looked more like hard limestone driveway. It has already been worked once this year with a road boss type and had about 15 small potholes from all the rain again. The parking area is about 1/2 acre and had a lot of grass that started to grow in the gravel. That was hit with round up in may so it was mostly dead.
Today the Grader arrived and I unloaded it and went right to putting it together. Once together I ignored the battery charging recommendation; I wanted to try this thing out. I worked the driveway first. First couple passes the front teeth just bounced around on the ground and did not seem to be doing much. I continued to go over it and it slowly started to break down and bring up the loose rocks. I ended up doing 20 passes over the driveway. It now looks like a fresh layer of rock was layed down and the pot holes are gone. Sure it took awhile, but it was fun and well worth it. I ran in high the entire time on the driveway. I could feel the engine working once it got broken up and moving gravel and digging in. On the parking area it did good in clearing the dead grass and leveling out the high spots. Since the parking area doesn't pack down like the drive it was moving a lot more rock. I had to run in low range 4wd to keep moving and not spin.
Overall it was a good 1 1/2 hour of work and it was fun. I think the driveway could use some more passes, but I will let it settle some and then hit it again. I would fully recommend the DR Power Grader. Yes it is on the light side, but it still dug in. No pictures because I was trying to get it done before the next batch of rain moved in.
   / DR Power Grader and 2305 #2
In the advertisement pics, they have cinder blocks to add weight. I wonder if in the excitement to try it out, you skipped adding them? Not trying to criticize... it's something I'm sure I'd overlook. In fact, I bought a York rake a few years ago and it really could use some added weight, which I never got around to doing before selling the house a couple of months after buying the rake.
Additional weight is optional. The tray can accept up to 70lbs. I wanted to see how it would do with out any weight. Next time out I will probably fill the tray with some type of weight possibly sand.
   / DR Power Grader and 2305 #4
I ordered a 60" DR Power Grader back in April to try out and to see if it really worked. They had a sale price, free shipping, extended warranty, and 1 year trial...
I was curious so I Googled to find what a DR Power Grader was. So took a look and since you state this is on trial... that looks more suitable for a vehicle lacking a 3pt (lawn mower or ATV) With a 2305 3 pt I'd think a grading scraper similar to a Landpride GS15 series would be better suited?
   / DR Power Grader and 2305 #5
I've had the 48" power grader for about 4 years. My driveway is hardpacked gravel with occasional stones up to 6" in diameter in it. I pull the grader with a 20 HP Sears lawn tractor. My observations:
The grader (sort of) works, but it takes many passes to get the job done, and the grader frequently gets hung up on larger stones, especially if the stones don't fit between the scarifying teeth. So I have to get off the tractor to clear out the larger stones. I occasionally add some 3/4" crushed stone, which is helping the situation. My driveway is about 10 feet wide, so the tire tracks on either side create a natural crown in the middle. My grading objective is to cut down the crown in the middle of the driveway and distribute the material into the tire tracks. However, because the grading blade is only about 8" high, the loose material is only distributed about 4" laterally on each pass. So it takes a lot of passes to get the material from the crown back into the tracks.
I can't take a deep cut with the scarifying teeth because the tractor doesn't have enough weight of its own (and therefore enough traction) to pull the grader.
The grader works better for me WITHOUT adding much weight to it. However, the oem battery and charger is junk, and so I now use a small car battery which I put in the weight tray. That's probably about 30 pounds more than the weight of the factory battery.
The overall quality of the unit is unimpressive. Some of the hardware is really cheap. Even though the unit is functional, I don't think I'd ever buy another DR product. I looked at their chippers at their NH retail store a few years ago, and was surprised to find that they wouldn't demo it for me, so I decided not to buy it. I spent $ 5000 on a used Vermeer 625 and I'm glad I did.
Don't be swayed by the 6 month return privilege. Once you get a DR product, you'll end up keeping it even if it's not adequate, because it's too much of a pain to return it. A money back guarantee is an inducement to buy something; well made products don't need money back guarantees.
   / DR Power Grader and 2305 #6
What do you have for a tractor.??
   / DR Power Grader and 2305 #7
Bob-
If you're ever in the market for a walk-behind brush mower, I hope you'd still consider DR, even though you say you'll never buy one of their products again. That is my favorite piece of motorized equipment I've ever used. Indestructible, easy to operate and knocks down anything in its path. Very high quality, to boot. Mine is at least 10 years old and operates as-new, having just replaced the belt on it for the first time this year.
I know nothing about the grader, but in most of the advertisements, it's being pulled by a 4-wheeler with weight. I've watched landscapers using 4-wheelers to roll newly laid topsoil and they go around and around and around the yard. My suspicion is that the DR grader is intended to be driven over the surface multiple times, chewing small amounts each time. So, for you it may be more time than you'd like... I mentioned that I had a Deere garden tractor/4' york rake combo at my old house and it took a dozen passes to get the gravel driveway broken up and smoothed over. I think it's just a function of lighter-weight implements. Unfortunately, cheap hardware is an issue unto itself and it's too bad because I'm sure you paid a lot for the grader.
   / DR Power Grader and 2305 #8
One key is moisture. Grade when it's raining or just after and it wil work the gravel much better. The DR is quite "toy like" for a guy that has a tractor.
2024 Bintelli ActivEV Pulse Electric Golf Cart (A42744)
2024 Bintelli...
Chutes Trash Chute (A42021)
Chutes Trash Chute...
CAT 436B (A42021)
CAT 436B (A42021)
Fleco 18" 6T Excavator Bucket (A42203)
Fleco 18" 6T...
2002 Mazda Protege Sedan (A42744)
2002 Mazda Protege...
1987 John Deere 455 Loader (A42203)
1987 John Deere...
