dr field weed mower
   / dr field weed mower #1
Anonymous Poster
Epic Contributor
I have some fairly steep hillside going down to our new pond that is going to need mowed, once all the clearing and construction is completed. As it is too steep for a tractor mower ,I have been reading about the Dr Field weed mower. Has anyone used or owned one of these machine? Any informa /forums/images/graemlins/grin.giftion would be appreciated.
Thanks- shortcut
I don't have any experience with the DR but I can say that an old Gravely L I with a 30" rotary mower with a brush blade is awesome! I got mine at a dealer- completely refurbished for $800. It destroys brush and branches up to 2" and is built like agricultural equiptment. Parts are still available, check out ebay or yahooo groups for further info.
   / dr field weed mower #3
No experience with that machine, but several forum members, including myself, do own or have owned the DR trimmer/mowers. Maybe some of them have that machine, too. Their prices are sometimes a bit high, but their products, warranty, and service are top notch.
   / dr field weed mower #4
SC,
I have had outstanding service from a DR Field and Brush Mower (14 hp model), and Country Home Products is great to work with. I have just sold this mower and purchased a new 17 hp model to get the wider cut deck (30 inches vs. 26). They offer several hp versions. Since you would be using this specifically on slopes, be sure to select a model that is rated for slopes up to 25 degrees (the max they offer).
The height of cut is about 3 inches and is not adjustable. It can take down very tall growth and saplings, but you have to recognize that it won't produce a "golf course" appearance cut. This is not a problem for me since I use this mower for ditch banks and rougher areas.
JackIL
   / dr field weed mower #5
Shortcut--
What follows is an edited version of a post I submitted last year. I bought a DR field & brush with the Kawasaki 15 hp engine for exactly the same use as you--mowing down to the pond bank. I returned it. Their money-back guarantee is exactly as advertised--no questions asked. It is a Rubik's Cube operation to get the whole think re-palletized for shipment back, but Country Home Products is definitely a class act.
I had some initial QC problems with the DR; the wheels were not shipped for the finish deck, and a couple of wires were misconnected (it would start fine, but would not shut down--had to pull the plug wires). But I worked it out with DR because the machine seemed like exactly what I needed for mowing steep banks and bushhogging woods trails. They were very helpful (although they sent the wrong wheel parts the first time), and extended the 30-day period to begin when I got everything (an extra two weeks). They shipped by ABF, and the driver unloaded the pallet into the driveway.
After giving it a good try--about 8 hours all told--I returned the machine because I found that it has no ability to traverse even a moderate slope; it heads off in the downhill direction and, even worse, lifts the high wheel off the ground as it does. While the limited slip is undoubtedly an excellent feature, I still found that with no slip on the grounded wheel, the one in the air would turn by itself--all in all, a precarious operation everytime I tried slopes from side to side. A 21" mower or a Gravely will do much better IMHO.
The DR can go up and down slopes pretty well. The transmission holds really well, and the brakes do too. But the power unit seems to have a high CG and the mower or cutter deck floats on a pivot point, so that it cannot contribute any stability at all if you get at all sideways--or even a bit diagonal. I also had some trouble backing it up steep slopes, which may have been due in part to the treads filling up with clay. I just didn't fill the bill for our hills.
All that said, there are many good things about the machine:
Decks really do change in about 5 minutes, once you figure out a routine.
The rotary cutter really will cut anything it can bend down. Also, it is lighter than the bush hog and will go up over some nasty stuff the bush hog insists on trying to eat--usually to the detriment of the shear pin. I was able to clear some scrub which had overgrown 3-5" logs, and the cutter cleared them off with no complaint so I could clear them out.
The finish mower deck does a credible, although not pro-mower, cutting job.
Good headlight.
Hour meter doubles as tach, oil-change timer, and probably some other stuff.
The Kawasaki engine seems great.
Here are the other down sides:
The controls seemed to me kind of cheap, compared to say a Scag or Exmark mower or a Gravely. The gear selector was a little jerky, wanted to skip first, and needed to be ticked into reverse. The dead-man did not work at all until I lubricated it, and then sometimes stuck, shutting the engine down when the blade was disengaged (I know this one sounds like operator error, but I watched it pretty close). Cutting requires squeezing a bottom handle (clutch) up and a top handle (dead-man) down on the same (left) side, which for me made it a trick to stop moving without the mower thinking I wanted to shut it down.
Turning is an all-manual operation. I was used to this growing up with and owning Gravelys, but the DR is harder to turn. Additionally, because the decks pivot from a center shaft at the top, the rotary cutter can swing sideways on a turn on rough ground, making a tight turn more challenging. All the more so on hills.
Hour meter came with no instructions, and after 6 hours, started to flash constantly. /forums/images/graemlins/confused.gif
Price. $3300 (cutter, mower, chains, light, hour meter).
The good news is you can find out for yourself and return it if you are dissatisfied. /forums/images/graemlins/smile.gif
   / dr field weed mower #6
I have a bachtold weed mower which I've used on steep slopes, and I have to agree that running across the slope can be a problem... The high position of the engine makes it want to tip over, and so you have to fight it.
Going up and down, or at an angle to the slope works better, but it sure wears a person out!
Brent
   / dr field weed mower #7
I have to go with what JPT says. I picked up two old Gravelys this winter, and have been using them for brush mowing. Work good. Not as easy as a tractor, but sence I do not have one yet, I don't have much choice. The old ones had full psi oil system, can add two wheels per side so its more stable on hills, and best thing, is they just don't die.
   / dr field weed mower #8
We use a DR field and brush mower with the 15 hp Kawasaki at our mountain home where it would be impossible to take a tractor. Rick summed things up pretty well and for our needs it has done a good job. Working side slopes in my situation is not an option though I can see how the mower would be hard to hold on a slope. For going up and down slopes it does a great job as long as it will maintain traction. We have some situations where we even winch the mower down hills with the ATV winch. It will cut most anything you can push over with it. It will also give you a pretty good work out but beats the old manual ditch blade hands down. I would rank it as a well-built solid machine backed by a good company if it meets your needs. We have a finish deck for ours also but have never used it so I can not comment on that.
MarkV
   / dr field weed mower #9
I rented a machine very similar to the DR (I forget the brand, it was either a knockoff or a DR with another label). I have a long step bank and had the exact same experience you describe. And rocks, forget about it. They might say it cuts like a big brush hog on a tractor, but without that hinged blade forget about it. Bent that blade like a piece of licorice on a softball sized rock. And those are tough to see when cutting waist high brush. I promptly brought the machine back and forgot the DR dream forever.
I have tried eveything and like a lot of you had problems. This will sound crazy but the best thing I found was an attachment to my weed eater. It is called the string trimmer caddy, it fits all brands of weed wackers and only cost around 20.00 it does a great job and also lets me get some walking in, to help get rid of the spare tire
/forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
28013 (A50322)
28013 (A50322)
