spruce Deere
Veteran Member
- Joined
- Feb 1, 2009
- Messages
- 1,133
- Location
- Northmost Idaho
- Tractor
- John Deere 790 with loader LS xr3140h also with loader plus a cab
Been awhile since I have been on tbn. Since joining tbn, some new "things" have become prevalent on compact tractors...
We recently purchased a brand new LS XR3140H. With a cab, heat, a/c, dpf other bells and whistles its QUITE a jump from the ever dependable JD 790.
Between plowing snow and other chores being done with the LS it has acquired 15 hours already, we got it home early December. I decided to do an early regeneration cycle for the dpf or 'diesel particulate filter' with some idle and none of the work was really done at higher rpm's but at full engine temp. On this LS tractor you can 'force' a Regeneration before it automatically does. It was about twenty minutes.
Researching the dpf regeneration topic, there is fuel additives that supposed to cut down and help with regeneration cycles and keep the dpf cleaner longer.
I have read in the owners manual on dpf cycling but would like some members input on 'diesel particulate filter' equipped tractors
