Dozer work #2 -- How much will it cost me?
   / Dozer work #2 -- How much will it cost me? #1
yeehaw
Bronze Member
understood different regions will vary -- but on clear cut land --- stumps mostly less than 3-4" tall and (most) a foot wide -- some of course wider -- what should i expect to pay to try and convert to pasture land (overnight of course :cool:) looking for a ballpark figure before i call a couple of guys to give an estimate
thanks
second post...
   / Dozer work #2 -- How much will it cost me? #2
Big equipment will cost more per hour, but get the job done quicker.
Small equipment will cost less per hour but take longer to finish the job.
If me, I'd get a bid for the job from the "guys".
   / Dozer work #2 -- How much will it cost me? #3
First thing I ask when someone calls and says they have stumps they'd like out................. how high did you leave the stumps? I like to see them as high as they can reach and cut the trees off, every foot of height they leave makes it WAY easier to pull them out. Then you can cut the remaining wood from them when they are on the ground.
Digging stumps is prob my least favorite thing to do. It's hard on equipment, operator and ya got to find dirt to fill the hole and also get rid of those pesky rootballs.
I don't think you'll find a bargin price to pull them but at least they aren't 3' in diameter. The ones I hate are Elm and also when multiple trees have grown close together and root balls intertwine. A decent size mini in the 12k range should be able to pop those 12" and under stumps out pretty fast but it's still a time comsuming job to clear. I've dug some really huge ones out with a smaller machine but just takes time.
Good luck, with everyone out or work you might find someone looking to start spring work early and get right on it at a decent price.
Topstrap
   / Dozer work #2 -- How much will it cost me? #4
Topstrap
You're not kiddin it's hard on equipment. Years ago I was building a house and had to cut down a big oak tree. The guy that put in my septic said he'd dig the stump and root ball out with his hoe for $25. He struggled with his 580E to dig the stump out. He finally got it but found out he had twisted the stick in the process.
I had another guy do the backfill and rough grade. I asked him to push the root ball out back so I could burn it. He said he'd haul it away for $25. For $25 I sure wasn't going to mess with it. He pulled his Case 450 loader up to it and we threw a chain around it and hooked it to the bucket. When he picked it up we heard a very loud PING. His loader bucket had broken.
   / Dozer work #2 -- How much will it cost me? #5
A good sized excavator will make short work of these stumps. I wouldn't waste my time with a dozer.
   / Dozer work #2 -- How much will it cost me? #6
I have hired D4Hs a couple of times I believe they are close to 30K pounds. Rates have varied from $65 to $100 per hour. Building a 640' long, 30' driveway and a 200'x200' yard including pushing over and piling up all the trees and spreading 400+ yards of city pit was around 22 hours. I burned the trees myself
i just cant see someone out there digging up stumps...in a 10 ft square area there are probably 2-3-4 stumps...multiply that by 20-30 acres and that is a whole lot of digging....thanks for the replies
   / Dozer work #2 -- How much will it cost me? #8
You may want to consider a 3 point hitch tractor mounted stump grinder, if you have access to a 40+ hp tractor. I think Worksaver and Wallenstein makes those and would be cheaper than a dozer and you could sell it after you are finished with the project. Ken Sweet
   / Dozer work #2 -- How much will it cost me? #9
Unfortunately, no matter what equipment you bring on site, that is exactly what will happen. Depending on type of trees involved, a 12" stump may or may not pop easily. Are there tops to contend with too? Is it legal to burn where the site is?
From your description, a large loader and an ex would be the best bet. Putting our Cat 953 and 325 on site and depending on tops, a saw guy @ $215 / machine hour. If we need a night watch for burning (area dependent) $40/hour. If burning is not an option, add a tub grinder for $275/hour. Then spread the topsoil/mulch mix.
Stump grinding, may not go deep enough to allow for plowing and discing, depending on what you want. A stump pit, while cheaper, would be my last resort for anything deemed pasture land. When the stumps decay, voids will be created,which can easily lead to bad things for farm critters.
   / Dozer work #2 -- How much will it cost me? #10
Where are you located
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2005 GENIE S-80 MANLIFT (A51246)
2005 GENIE S-80...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
1269 (A50490)
1269 (A50490)
BESTWAY LOT IDENTIFIER 19 (A53084)
BESTWAY LOT...
