Dozer Technique
   / Dozer Technique #1
have_blue
Veteran Member
Eunice, Louisiana
L4400
I've spent a good part of the last 3 days digging my 1.5a pond with a JD650H. Like any other machine or implement, I'm finding the digging part is easy, and the carrying part is s-l-o-w!
I am used to the machine, and I can handle it just fine, but I'm at a loss as to what the most efficient way to move dirt is. I know it's best to push the dirt the shortest distance possible. Well, that's out. I only have 1 place left to push the dirt, and that's almost 500 feet at times. What's the most efficient way to push the dirt such great distances? Should I push up piles every 40 feet or so, or try to carry each load the entire distance? I would really appreciate some advice. My rear end can't take much more of this! :)
Thanks in advance,,,
   / Dozer Technique #2
When you start to push don't try to take everything at once then in 3-4 passes you will have a windrow built up on both sides LEAVE IT THERE then everytime you make a pass stay between the windrow works like having wings on the blade. then right at the end move to one side or the other if you need to pile up the dirt you can push 2-3 times as much this way
   / Dozer Technique #4
Dirthog has it right.
Catapillar did a study on moving and digging dirt the most effective way. They found that keeping the dozer on the same tracks every pass is the most effective method. You want the ditch, or spoils to act as walls to keep the dirt on the blade.
Then they found that you start at the closest postion and work your way back. In other words, where you want to spoils to end up is where you want to start moving from. Or the closer the better.
It becomes inefficient over distance because of all the time you spend backing up. Your just burning fuel and not accomplishing anything. Since you can't help it, keeping the dozer on the same tracks will minimize the amount of wasted time.
When your done with the pile, then you start at the furthest point and start working the edge piles into the trench and back onto the same tracks you have been using all along.
One advantage of moving loose soil is that it takes allot lest power than digging it out. Less power means less fuel consumption!!!
Where are the pics?
Eddie
   / Dozer Technique #5
I concur. But you owe it to yourself to wear GOOD ear protection. I remember doing exactly what DHog is talking about on a D7. Going forward (pushing) is OK, but the reverse trip makes the tracks "clack" going back over the rear sprocket. You'll be luck if you can hear anything after about an hour.....Trust me on this. Can I get an AMEN from the Choir?? BobG in VA
   / Dozer Technique #6
I have worked on 2 ponds with my old D7, I finally hired a friend with a rubber tired front end loader with a big bucket to move loose dirt piles out of pond. figure cost of getting a lot of dirt moved cheaper than making all those trips back and forth with dozer. less dozer fuel and wear and tear. use dozer to dig and loose dirt use loader to carry the dirt out and dump it where you want it. good luck . agh
   / Dozer Technique
Got it! Makes perfect sense!
I had all the pieces, but you put it all together for me.
Thanks!!!
   / Dozer Technique
Catapillar did a study on moving and digging dirt the most effective way. Eddie
I had a feeling a study had been done, and I had a feeling you would know about it! :)
I know backing up is inefficient. I also know that it causes extra undercarriage wear. The undercarriage is 95%, and I need to keep it that way as long as possible. But like you say, some backing up can't be helped.
Pics are on the way!
Many thanks Eddie!
   / Dozer Technique
BobG and AGH,
I hear you on the hearing protection. I intend to get some noise cancelling headphones to listen to talk radio while I work. I do like to hear my engine and tracks, so I will not tune them out entirely even if I could.
In earthmoving, the digging is easy, the transporting is always the hard part. If I had a big, fast wheel loader to clean up after the dozer, I could dig my pond in no time flat. That 650H really digs fast.
Thanks guys! Your helpful replies really hit the spot!
Now I gotta go fuel up. :( :( :(
   / Dozer Technique
EddieWalker said:
Where are the pics?
Pics as promised.
Here's the dozer. It's a JD650H, and it's in excellent condition. The blade is 105", and that's the only drawback. The shorter blade digs real good, but just doesn't cut it for pushing dirt 400'! The A/C is sweet. It will freeze you out on the lowest setting. Ear muffs keep it super quiet, and I can tune my ears for any new noises or vibrations.
http://i31.photobucket.com/albums/c394/bobad/9fce67f1.jpg
Here's the pond monster, making my old truck look even smaller than it is. It eats men and machines for snacks. At over 400'x150', it gives up every yard of dirt grudgingly. It's a shame the 2.9 YD. capacity blade won't carry that much dirt. I could lean it back and carry more, but the sticky clay would probably not drop out cleanly.
http://i31.photobucket.com/albums/c394/bobad/Picture039.jpg
Here's the "groove" you guys suggested to carry more dirt. It helps considerably. (thanks!) The camera lens doesn't do justice to the distance. It's a long way to my truck!
http://i31.photobucket.com/albums/c394/bobad/Picture034.jpg
Here's the 2 or 3 yard earth mover I'll be using as soon as I get a new hydraulic cylinder for it. Pulling it with a 125hp Kubota tractor, I can easily move 200 yds. of dirt a day with it. Compared to the size of the pond, that's still not much! I'll still be using the dozer to square off the corners of the pond and doing some landscaping.
http://i31.photobucket.com/albums/c394/bobad/Picture012.jpg
I can't wait until this large, raw scar I made on the earth is filled with soothing water. I'm hoping to flood it this fall, but the prospects are not looking so great. The rainy season is fast approaching!
I have a new respect for dozer operators. Now I know why they command so much respect and are paid so well. Not only because of their knowledge and skill, but also because they have an ability to endure pain that few men have! :)
I would sacrifice 2 daughters and my fattest goat for use of a track hoe and dump truck for a week! :)
2020 Massey Ferguson 6713 4WD 125HP Tractor (A44789)
2020 Massey...
1978 LUFKIN TRAILER (A45046)
1978 LUFKIN...
TAG 36in Excavator Bucket (A44391)
TAG 36in Excavator...
1999 Ford F-550 Flatbed Truck (Diesel), VIN # 1FDAF56FXXEB53781 (A44391)
1999 Ford F-550...
WANCO 6K LIGHT TOWER (A45046)
WANCO 6K LIGHT...
2018 NRG NIRG TRAILER (A45333)
2018 NRG NIRG...
