Dozer Advice
   / Dozer Advice #1
Sota
Northeast Mississippi
L3430
Hello,
I am looking at a 1990 Case 550 LT and a JD 650G. Both of these have about 4300 hours on them. The 550 is described as follows; undercarriage - 16" pads pins/bushings,sprockets 80% good bottom rollers & front idlers powershift trans, pedal steer 4 post ROPS w/sweeps. The JD undercarriage is in about the same condition. The Case is priced at 19,000 and the 95 JD at 26,000. The JD was a one owner dozer and used on a farm I believe. I do not have much history on the Case. I will be using the dozer to clean up about 15 acres around the house and will use it to do clean up on some cutover land. It will also be used to do brush and light duty clean up at a couple of other 30to 80 acre tracts. Any input about these two dozers and brands would be greatly appreciated.
Best regards,
Sota
   / Dozer Advice #2
Buddy of mine has a Case 450 dozer and we can't kill it. I hope when he gets tired of it, he'll sell it to me cause that thing is tougher than a bull.
I'm sure the Deere is a fine machine, but this Case we got over here is a tough SOB.
   / Dozer Advice #3
The JD 650 is gonna be quite a bit bigger then the Case 550. Between the two companies, I like Case better then Deere. I'm not sure of the engines in either, but in bigger Case equipment, it's all Cummins. I like Cummins engines allot. I've run a JD 450 Dozer and it's a fine machine, but if you ever have to change the sprocket, you have to remove the track to do so. On the Case dozers that I've seen, you can replace the sprocket in segments.
Rule number one with dozers is bigger is better. You can do more, faster and easier with a bigger machine.
I paid $25,000 for my 1988 Case 1550 dozer. It's 168 hp and weighs 40,000 pounds with an 8 way blade. Hours are usualy wrong on equipment.
I don't know your area and haven't priced anything lately.
Here is a webisite of where I bought my backhoe. His prices are very competitive and a good place to get an idea of what stuff is selling for.
TNT Equipment - Your resource for farm and construction. John Deere, Kubota, Ford, Caterpillar, International, Case, Hyundai, New Holland, and more.
He has a Case 850B Dozer for $18,000. I don't know if that's what your looking for, but if I had $20,000 to spend, that might be one I'd look at.
Eddie
   / Dozer Advice
Thanks for the feedback guys. I am trying to keep my weight down as I do not have a cdl and will be moving the dozer quite often. I am trying to strike a balance between power and being able to move it safely.
Best regards,
Sota
   / Dozer Advice #5
If trailering it is a priority, then you need to determine what you weight limit is. That JD 450G that I ran was small enough to tow around with a one ton pickup truck. Lots of builders use them with some skid steers to build pads and clear a lot for building a house.
The guys with the ten wheel dump trucks can pull bigger stuff, but still nothing huge.
What are you towing with?
Eddie
   / Dozer Advice #6
I think you will find you are out of luck with either one the case will weigh over 9 tons the jd more than that you are at 18000lb for the case the limit for CDL for a trailer is 10000lb total so you are 8000lb to start with and I could be wrong the 550 case may weight more that that.
   / Dozer Advice
Thankfully, my cousin is in the logging business and I could have him move a larger dozer between the longer tracts. The case weight is listed 14,000 on the specs that I was sent. Would a 1 ton and a bumper trailer not safely carry the case between the short tracts? I can get a farm tag, as I am using it on my pine plantations.
Best regards,
Sota
   / Dozer Advice #8
I would never try and pull that much weight with a bumper pull trailer also as I said even at 14000lb you are over CDL and that does not include the weight of the trailer yet! I don't believe there is any way to get around the CDL ratings by claming a farming use.
   / Dozer Advice #9
Read your state farm tag CDL exemption regulations. My state exemption is specific to carrying farm grown product to a nearby market. Toting machinery does not qualify for the CDL exemption.
If you put the dozer on a farm trailer behind a tractor???
I have a dually 1 ton dump & tote a JD 350 dozer on occasion with a bumper pull. I stay under the 26K limit even with a 2750 lb QT backhoe riding along. It's a small landscaping dozer.
Many states including mine are requiring a CDL for commercial use of a over 10K trailer as well.
   / Dozer Advice
Thanks for all the advice. I can reach 3 of our tracts just by driving the dozer to our property line and then loading it and trailering it across a paved country road and reach the tracts around the house as our land is connected. I would have to do this twice to reach the all the tracts around the house. I could not do this with all our tracts. First, I will not tow anything without being properly equiped and legal to do the job. I own a mini mart and one night the floors were being mopped and we had the wet floor signs out and a woman came in and slipped on the floor. The manager asked if she was okay and she said she was not hurt. She left and drove staight to the ER and we got sued. Too much liability out there to take a chance. Also, I have consideration for others as I would not want to tow anything in a unsafe manner that would endanger other motorist.
Best regards,
Sota
2012 AMERITRAIL, INC. T/A 32’ GOOSENECK (A45046)
2012 AMERITRAIL...
2008 TRAIL MASTER, INC. GOOSENECK TRAILER (A45046)
2008 TRAIL MASTER...
John Deere 5055E Tractor with 520M Loader, Low Hours, Limited Warranty Until 2027 (A44789)
John Deere 5055E...
2016 Ford Explorer SUV (A44572)
2016 Ford Explorer...
40ft 5 Dual Door Shipping Container (A44571)
40ft 5 Dual Door...
2019 Chevrolet Express (A44501)
2019 Chevrolet...
