Downsizing a good thing or bad
   / Downsizing a good thing or bad #1
case245
Platinum Member
pa
kubota 7040sud
I thinking bout trading in the M7040SUD FOR A M5140 hydro shuddle a few reasons the 7040 is manuel im tired of shifting and I want the assist cylinders on the 3pt is the 148 cu in engine in the 5140 going to be to small I was pulling last eve on the 2nd pass the 7040 was grunting even at 2000rpms in 4wd pulling 3 bottom 16'' boards so is the 5140 going to be able to handle that task or is it going to stall I also drag logs with my tractor I don't know if it will handle that my 7040sud has a 203 cu in engine
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
John Dozer JD650 (A53421)
John Dozer JD650...
