Posthole Digger Down pressure PHD
   / Down pressure PHD #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Ran across this PHD searching the web and this is a very interesting unit.I like the hydraulic down pressure. Has anyone seen or used this.Maybe we could make one.It's made by Hodge industries in Australia.
   / Down pressure PHD #2
Looks very simple, could also be done with a manual cylinder like on an engine hoist and if you have one already, you could borrow it with no additional expense.
Jim
   / Down pressure PHD #3
They make a kit for it but I have yet to need one, usually if it stops digging it is because something is in the hole. Remember this is a drill it pulls itself into the ground. If it isn't it is because there is something there or the tip is dull or broken
   / Down pressure PHD #4
In Arizona, the caliche is so hard, that a 6" dia. bit will sit and spin until it makes a shiny spot. We have to make a starter hole with a pickaxe and add water to get the bit started. Keep adding water while drilling and 20 minutes later we will have a 3' deep hole.
   / Down pressure PHD #5
That downpressure kit looks a lot more serious than the ones that come from Land Pride. Of course, if it can lift the tractor's rear, it's adequate.
We have a cilica cemented hardpan called durapan. Thickness varies from 4'-16'. It's water impermeable. Augers have to have carbide fishtail tips (usually Pengo) and the PHD has to have downpressure.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
378788 (A51573)
378788 (A51573)
