Chilly807 is spot on with his description.
I had a
L3650 DT-7 for thirty years that had a dual stage clutch. In certain situations it was very useful.
An example is when rototilling. You can let out the clutch halfway to start the rototiller tines turning and then let it out all the way to start the pass. Bush Hogging and flail mowing had a similar advantage.
When using a
chipper the clutch could be slipped to engage the
chipper drive (while the tractor was is neutral).
Using the chipper on my BX with HST you have to rev it up, slam it into PTO, and hope it doesn't stall. Some say the PTO engage lever can act like a clutch and feather it in but I haven't been able to master the technique.
