Don't buy DURO brand trailer tires
   / Don't buy DURO brand trailer tires #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Purchased a 6X12 aluminum utility trailer from a local business back in early 2009, it came with Duro ST205/75 D-range tires. After less than 4000 lightly loaded miles with proper inflation pressure, despite my efforts to preserve the sidewalls with Protect-All and keeping the tires covered when not in use:
The sidewalls are badly cracked down to the cords, and the tread, although almost new depth, shows extreme cracking at the bottom of the tread. These are the worst tires I have ever owned, and I hope this information helps another trailer buyer avoid such a poorly made product.
   / Don't buy DURO brand trailer tires #2
Trailer tires seem to die from old age before mileage.. you got 5 yrs out of them, that is about max life anymore..
Brian
Well...we are told that ST trailer tires are specially made to resist the effects of weathering...tell you something....I have a '95 vintage Jayco 30' TT that has the OEM ST Goodyear Marathon radials, it gets used at least once a year, but the tires look MUCH better than the Duros do...if 5 years is considered a normal life for trailer tires made today, screw it....I will just use regular tires
   / Don't buy DURO brand trailer tires #4
It is hard for me to believe that you did not do that years ago, I have.
   / Don't buy DURO brand trailer tires #5
I have had good luck with car tires on my trailer.
   / Don't buy DURO brand trailer tires #7
I just bought a used Hurst trailer, 1998 model with the original Duro tires on it. They too have cracked sidewalls and I intend to replace them......but they are 16 years old......
   / Don't buy DURO brand trailer tires #8
Do not use car tires on a trailer. They do not have the same load capacity as trailer tires.
That depends on the tire. If you use car/truck tires, check the weight rating before buying and make sure they are heavy enough.
Aaron Z
   / Don't buy DURO brand trailer tires #9
Most ST (trailer tires) are made in china today, doesn't matter what the brand... and they're all cr*p...
There are still a few made in the usa, but you have to look.
I had three blowouts in a 600 mile stretch, down in Baja, Mexico, one had been installed for a year, had about 2000 miles, the other two were new unused spares, kept inside the trailer (no UV) .
First spare lasted 3 hours, the second a day and a half.
First thing I did after crossing the border was new tires all around, and the best I could get were made in Mexico!
If you can get 5 years out of a "modern" ST tire, I'd say you did very good!
   / Don't buy DURO brand trailer tires #10
For trailer tire discussion look at some threads on the Trailers & Transportation forum.
Diamondpilot pretty much has us convinced that Greenballs are among the best.
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
CAT 973 (A47384)
CAT 973 (A47384)
2016 MACK CXU613 SLEEPER TRUCK (A52576)
2016 MACK CXU613...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
