Dongfeng disc brake oil seal replace
   / Dongfeng disc brake oil seal replace #1
SquareWheels
Coulterville, CA
Dongfeng
The rear brakes on my 2007 Field Pro (Dongfeng) DF254G2 tractor have been progressively less effective over the last few months. The internals of the left-hand brake assembly looks normal; at most the disc brake lining may be a bit glazed. The right hand brake has problems. A leaking oil seal is probably at fault. The interior of the assembly, including disc, is covered in hydraulic oil.
Does anyone know the procedure for inspecting and replacing the seal? I have a service manual, but it covers only preventive maintenance, not repair procedures. I'm hoping I do not need to remove the ROPS.
Thanks for considering my request.
Steve
For anyone needing to replace the brake input shaft oil seal -- It was necessary to remove the ROPS prior to removing the brake housing. When removing the brake housing be aware that there is a bearing carrier plate sandwiched between the axle housing and brake housing. Also, the carrier is shimmed for bearing preload.
Now I wait for parts.
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
JOHN DEERE Q820M LOT NUMBER 80 (A53084)
JOHN DEERE Q820M...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
SHOULE LN-16 LOT NUMBER 69 (A53084)
SHOULE LN-16 LOT...
