Done with winter
   / Done with winter #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
I finally got the BX2230 out today and pulled the snow blower. But before it came off I run it a little to warm the gearbox oil before I drained and refilled it. No sign of moisture in the oil and just a small "scum" of silver? on the oil. I don't know what you guys use, but I use Marine lower unit grease, the same as I use in my 3 outboards. It's GL5 rated and friendly to all metals.
I built a dolly and store it auger down. If you ever store yours that way and the breather nut weeps oil, just get another plug screw (all 3 are the same thread) and install that for the summer.
Put the breather nut in a baggie and wire tie it to the blower where you can't miss it so you can switch them next fall.
   / Done with winter #2
Took the blower off the front of my JD 855 about 10 days ago.
Figured it would snow for sure when I did that. Not yet.
Left the chains on. And have got a little rough dirt work done around the yard that I need to do.
Now it is threatening to rain so I can't complain.
(toyboy....... Birchwood Wi here)
   / Done with winter #3
Same here,drop the plow and frame store away until Nov....seems like old man winter was on vacation.
   / Done with winter
Hey there Wyobuckaroo, I need to get over you way some day and check out the gun shop that advertises in the Shoppers. Maybe we can get together for coffee?
   / Done with winter #5
One of the warmest and dryest winters on record here in Kansas. With lots of rain here in the eastern part, I've mowed three times. The chains and plow came off a month ago. The early garden seeds have been in for a month and are well on their way. I hope the potato sets haven't rotted due to so much rain. Now, if there is no late freeze, crops should be great and ahead of the real heat.
   / Done with winter #6
My snowblowers was attached to the tractor for about a week this year: a couple days before the blizzard until a couple days after - no complaints though.
I'm not going to completely put it away until after Arpil 1. A few years ago we had a Fool's Day storm, and I wouldn't put it past mother nature to do it again.
   / Done with winter #7
I got sick of clanking up and down the road with the chains flopping around fetching round bales, so I dropped 'em where the tractor stood in the barn yesterday...
   / Done with winter #8
Sure wish winter was over here. Sunk two tractors yesterday...and here's what Accuweather says today :eek::eek::
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2013 Nissan Sentra Passenger Car, VIN # 3N1AB7AP8DL772101 (A50324)
2013 Nissan Sentra...
