domeries tandem disc
   / domeries tandem disc #1
deandesperado
fresno, ca
ford
new to farming, new to post. question is how do i set my disc to make furrows with i peak in the middle and how do i set it to make the row flat and even with just a little furrow on the outside??? thanks in advance.
   / domeries tandem disc #2
Welcome!!! first set the frame level front to back and side to side when in the ground. Set the gangs at about the same a angle so that they cut pretty well. That should be a good start to leveling land. Adjust the gangs so that it is fine tuned. To hill set front gang as little of an angle as you can and the rear as much as you can. Try that it should get you started.
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
2025 IR UNUSED Hydraulic Thumb (A53117)
2025 IR UNUSED...
Genie Scissor Lift (A53421)
Genie Scissor Lift...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
