Dollie for 3720. BH
   / Dollie for 3720. BH #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
Anyone ever make a dollie to move around the garage when removed .
   / Dollie for 3720. BH #2
you could use a jack that's made for splitting tractors and let the bucket sit down on a skid roller
Never saw a jack like that any link to that kind of jack
Sent from my iPhone using TractorByNet
   / Dollie for 3720. BH #4
Well I cant find a pic of one like I use but its just flat metal with 4pipe legs at the corners and the bottom platform is the same but with a size smaller pipe so the top will fit and slide over it... heavy bottle jack in the middle and slab wheels like on an engine lift
   / Dollie for 3720. BH #5
I have seen dollies that car tires sit in used. There made to put under each wheel of the car, then you can push the car sideways in to a corner.
Going to remove bh look at it off and try to come up with something harbor freight has a motorcycle dolly looks like it will work 1250lb capacity
   / Dollie for 3720. BH #7
I bought 4 of the wood dollies from Harbor Freight, the ones that hold 1000 lbs and are always on sale. Put a piece of plywood to fill the void, and bingo backhoe mover. Oil the bearings before doing anything. I put one under bucket, one at the forward point and the other two under the foot pads. Then you can move it where ever you want, on hard surface.
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
RIGID TOOLBOX (A52472)
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
INSPECTION (A51572)
INSPECTION (A51572)
