Doing a hyd post hole digger.
   / Doing a hyd post hole digger. #1
Dwiz
Kubota B 2301
Just got a couple of questions on the hydraulics for my post hole digger. Im using a 3.18 gear box with a Danfoss 6.9 cu motor mounted off the ssqa. I plan on using the power beyond from the backhoe to a valve, then to the motor. The question I have is there is three lines for the Kubota BH 70 backhoe and three lines that can be hooked to the valve P,N,T. Is line T coming off the valve a low pressure line going back to the tank? I believe the line coming back from the backhoe is a low pressure. Thanks
   / Doing a hyd post hole digger. #2
Sure you have enough flow to spin the motor sufficiently? Don't believe the B series Kubota has enough flow but I could be wrong.
Manual says 4.7 so I figure 4. That should give me about 40 rpm at the auger bit.
   / Doing a hyd post hole digger. #4
...Is line T coming off the valve a low pressure line going back to the tank?....
Yes, and that is the only hydraulic line that can have a "T" connector (multiple lines connected together; all low pressure return to tank.)
   / Doing a hyd post hole digger. #6
When you get it hooked up and working, please let us know how well it works. I sold my PHD and bought a Shaver post pounder, much quicker, no backfill and it will pound RxR ties too.
   / Doing a hyd post hole digger. #7
If you bh is end of the line maybe it doesn't have pb. You may have to grab the inlet of the bh valve.
I only have about 50 post to put in. The soil is clay with some rock but when its done I will post pics and maybe a video. I know alot of people have posted on what torque, speed and gpm is needed so were gonna find out. I should complete the project by the end of Feburary.
Comes from the loader through the BH and to the 3 point. I installed the BH and lines and knew the blue line was low pressure just didnt know if the valve was low pressure return.
City of Tampa (1202)**Title MUST be transferred into buyer's name INCLUDING DEALERS. All titles (A51692)
City of Tampa...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
