Dog Ate It - starting problem
   / Dog Ate It - starting problem #1
fishpredator07
Colorado
L3130
Really, she did. trying to get a squirrel. L3010HST
Anyway, fixed the wiring harness to the rear lights, hydraulic fitting, and fuel line she destroyed but having starting problem, i.e. getting power to the starter.
Long story short, I can jump the starter and start the tractor. What I can't do is isolate where the fault is yet. Think I have a problem with the black wire with white stripe from the back of the ignition switch to the starter.
I can get continuity from the connector attached to the starter relay down to the starter. I can't get continuity from the connector behind the dash connected to the ignition switch to the the connector at the starter relay or the starter.
Questions:
Obviously, what lies between?
Anyone have a readable wiring diagram? Not the one from the parts manual. I have that, and its just not suitably detailed of the areas I'm concerned about.
How can I test the starter relay?
I'm electrically challenged, so be kind. Thanks,
J
2008 New Holland L175 (A47477)
2008 New Holland...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
