I took my FEL off for the first time and when I turned off the tractor, I ran the controller arm around several times to relieve the Hydraulic line pressure. When I went to reattach the FEL a few hours later two of the lines still had so much pressure in them I could barely relieve them by poking the valve with a screw driver. Is it always gonna be this way?? When backing away from your attached FEL, does both your arms disconect from the tractor the same time or does one disengage earlier than the other as you are backing up from the FEL??
