Does the injector pump on a 1920
   / Does the injector pump on a 1920 #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Does the injector pump on the 1920 get oil from the engine, or does it have its own oil resevoir? I know some of the older fords had seperate oil res'v. I'm getting ready to service my machine and couldn't remember.
If yes, any tips / hints / instructions?
thanks
Soundguy
   / Does the injector pump on a 1920 #2
<font color="blue">...does it have its own oil resevoir?... </font>
Every injection pump I've encountered is lubed via the "diesel fuel" that feeds it... that's why you don't want to keep cranking them dry when you run out of fuel... /forums/images/graemlins/shocked.gif
   / Does the injector pump on a 1920 #3
The 4 cylinder ford (such as on the 7700) did indeed have it's own oil resovoir on the pump which needed engine oil, and changing something like every other regular oil change.
I'm not sure about the imports, I'd guess not, but don't know - I better find out, I got a 1720 that is getting close to it's oil change! /forums/images/graemlins/smile.gif
--->Paul
   / Does the injector pump on a 1920 #4
The injection pump does not have a separate oil reservoir like the Simms brand pumps used on some of the older tractors. The cam lobes that operate the fuel injection pump are part of the engine lube system, and the cartridge with the injectors is lubed by diesel fuel. Hope this helps.
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
