Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option?
   / Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option? #1
ampa
If it does how can I tell if it's maybe already factory set on DC,I have been told if I run a gassless unit then it should be connected to the DC cause it runs better on the DC side,which maybe mine is factory set already to run on DC I've no clue as I've misplaced the operating manual due to movin',I have some weldin' to do,and I'd like to get a clear picture in my mind how to make sure it's only runnin' in a DC mode>>>>>>thanks in advance>>>>Ampa :)
   / Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option? #2
I dunno nuttin' about welding ... yet! ... but I think you should be able to find the manual here: Browser Level Verification
   / Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option? #3
AFAIK all mig welders are DC. The polarity is switched depending on whether one is running MIG (gas shielded) wire or flux core wire.
   / Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option? #4
Its DC..All MIGS are, but depending upon how yours are configured, it could be DC + or DC-.
   / Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option? #5
I would look on line for an instruction book.
Dan
   / Does my new 120 volt 125 Lincoln Mig Welder have AC/Dc Option? #6
Open the cover and look at the two 1/4" thick wires that are next to the trigger leads. Ther is a + by one and a - by the other. Follow one wire to your ground and the other hooks to the block that your feed rolls are mounted on. If you use Gassless Wire. The Ground should be hooked to Possitive or + on that unit. Opposite for Gas.
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
JOHN DEERE LOT NUMBER 167 (A53084)
JOHN DEERE LOT...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
