Does MFWD replace HP ?
   / Does MFWD replace HP ? #1
Beavis
Kansas
JD 4720
When shopping for a new tractor, how much less HP rated tractor can you get by with if the tractor has MFWD? For example if you look at the "great plains" website they have minimum HP requirements for some of their products: drills, field cultivators, etc.
With this in mind, let's look at the JD 5 series:
How would a 5075E (2 wheel drive 75hp) compare to a
5055E (MFWD 55hp) ?
I know that the 2 wheel drive vs. MFWD has nothing to do with the overall hydraulics of the tractor; my concern is more about ground engaging impliments; disk, field cultivator, etc.
THANKS
   / Does MFWD replace HP ? #2
It's very difficult to say. Clearli ihf thev75 hp tractor can get all it's power to the ground it will be able to outpull the 55 hp 4wd or not.
Things like tractor weight, tire size and type, ballasting and numerout other factors come into play.
You may want to look at the Nebraska tractor test data and compare drawbar hp. I think you may find that a properly ballasted 75hp 2wd will outpull a 55hp 4wd.
Andy
   / Does MFWD replace HP ? #3
The only thing that 4wd gains over 2 wd is the weight difference. You can get more traction with less weight with a 4 WD and therefore you have less soil compaction. As for pulling, as stated before, a properly ballasted and tired (meaning you may need dual wheels) 2 wd will pull just as much as a 4 wd of equal HP. THe 4 Wd will just do it will much less weight. Now in muddy soils, the 4 WD is at an advantage since first it likely weighs less and therefore wont rut as deep and you get more balance traction, so it may go further in the mud and pull more than the same HP 2 WD with lots of ballast and bigger tires or even dual wheels. Most of the CUT and SCUT tractors are 4 WD so they can pull more with the lighter weight that they all have compared to the Utility grade farm tractors.
   / Does MFWD replace HP ? #4
I know we've discussed this in the past, and I've posted in the past that a full time farmer (primarily hay business) who had 3 John Deeres in the hundred HP range, all 2WD, told me once he'd never buy another one without the 4WD because it gave the equivalent of 25% more power. Of course the reason it seemed like that much more power may very well be what Gary has said.
   / Does MFWD replace HP ? #5
That is the exact reason several farmers and two different tractor dealers told me is the reason why 2wd is "extinct" in the modern farm except for pulling carts and the like. I'm told (which means I have no personal experience) that soil compaction has a major impact on crop growth and volume. One farmer next to my remote property uses triples on each corner of his large (450 hp or so) tractor and says he has less ground pressure than he would if he were using an old 8N tractor!
   / Does MFWD replace HP ? #6
Which is, I guess, the reason a lot of commercial farmers use rubber belted track tractors
8R/8RT Series Tractors
My neighbor uses his old steel track D7 Cat to rip and disc his alfalfa fields and says it produces less compaction than his MF 294S 4WD tractor even though the D7 weighs about 4 times more than the 294.
   / Does MFWD replace HP ? #7
Some tractor manuals will give you an idea on size of implements you can use with them. They normally give you the info for 2 wheel and 4 wheel if that model can be bought either way. I would think they will be safe in their figures.
   / Does MFWD replace HP ? #8
You can look up the specs on most dozers and they will often show the ground pressure to be around 7 psi or something close to it, so something like a bicycle with 80 psi should compact the soil more than the dozer.
   / Does MFWD replace HP ? #9
Of course. Just over a much smaller area. :)
   / Does MFWD replace HP ? #10
In a nut shell if you need pto power HP is king. If you need pulling power MFWD is king.
Here is my situation. I have a Ford 861 Powermaster 48HP 2 Wheel Drive.
My second tractor is a Jinma 284 28HP 4 Wheel Drive. The Jinma will out pull the Ford any day of the week. It does not matter if I am pulling out a stuck truck, logs, 2 bottom plow, ect it just plain out works it. Nothing wrong with the Ford and its great for PTO jobs like Bush Hogging but when it comes to 95% of the task I do the Jinma out shines it.
Chris
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2013 KENWORTH T800 KILL TRUCK (A53843)
2013 KENWORTH T800...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
2013 Ford Taurus AWD Sedan (A51694)
2013 Ford Taurus...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
