canoetrpr
Veteran Member
- Joined
- Aug 7, 2005
- Messages
- 2,396
- Location
- Ontario, Canada
- Tractor
- Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I'm in the process of installing a 4 spool valve with only plans to use two of the spools for now for top and tilt cylinders.
Trying to decide if I should even bother with getting QDs for the work ports that are going to be used for the top and tilt cylinders. I don't plan to disconnect them unless I need to take a cylinder in to be fixed as I have two other spools that are unused for anything else I need.
Does anyone regularly disconnect their TnT cylinders from their work ports to make QDs worthwhile?
