Does anyone make an ez lube plug that lasts?
   / Does anyone make an ez lube plug that lasts? #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
My rubber plugs on the bearing caps are constantly cracking and causing grease to leak out on my wheels and tires. The last set I put on was about 6 months ago. I replaced all 5 wheels and tires and added canvas covers at the same time. I pulled the covers today and found all the plugs cracked and they have never seen the light of day. Does anyone make an ez lube plug that lasts?
   / Does anyone make an ez lube plug that lasts? #2
Bearing Buddy
   / Does anyone make an ez lube plug that lasts? #3
I get 5 years or so out of mine or more. Could it be the grease you are using?
Chris
   / Does anyone make an ez lube plug that lasts? #4
mine are all cracked and sling grease all over the wheels, but I think they lasted about 5 years before it started?
Using the Ford/Merc spec molly grease. Only WB grease I've used for 40 years and never had a bearing fail.
I don't think a bearing buddy would fit over the EZ LUBE fitting.
I like the EZ LUBE design because it pushes grease through both bearings from the center.
I may try to make a mold and cast some from silicone or something.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2022 NORSTAR (A52472)
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
