Does anyone know how to bypass reverse PTO kill switch on an LT 2180
   / Does anyone know how to bypass reverse PTO kill switch on an LT 2180 #1
indianrider
cub LT 2180
I'm new to the site and hope someone can help.
I've been searching for a wiring diagram for the LT 2180 in order to find the reverse switch location and get a visual on it.
the new units have a new position on the ignition switch that bypasses this switch.
I have looked all over the tractor and found nothing attached to any pedal or linkage that remotely resembles a switch.
CAN ANYONE HELP?
Roland
   / Does anyone know how to bypass reverse PTO kill switch on an LT 2180 #2
I "believe" if you take off the mower and look under the tractor, follow the linkage for the reverse pedal, there's a little stub plug that disconnects the PTO.....at least that's how I "heard" where it is.....;)
I also "heard" that if you put a small wedge of wood to hold it up/in it will allow you to mow in reverse.
the LT 2180 is a shaft drive hydrolic unit. I just want to make sure exactly where it is
Is it on the tranny?
I use this tractor for snow removal the constant on and off of the pto tears up the belts extremely quickly .If the impeller gets jammed by heavy crusted snow because it is not spinning the belt is destroyed ($40 bucks a pop) just needless
this is what I need the switch disabled for!
   / Does anyone know how to bypass reverse PTO kill switch on an LT 2180 #5
I do not know your model but here is an idea. If you already have a push button reverse kill switch why not add a manual toggle switch beside it and use it that way for your winter work. Come summer you can reach behind the cover and remove the jumper to protect younger drivers.
Craig Clayton
sounds great, but I don't know exactly where the switch is located. easy enough to break either line to disable it.
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
