Dodge Cummins Transmition
   / Dodge Cummins Transmition #1
meledward23
too close to Graceland....
1025R
I have a 1996 Dodge Cummins. I believe I have had melt down with the transmission. My mechanic, said up, time for you to get a rebuild. See yeah. My Mechanic won't touch dodge. He has enough business to be very picky.
Anyway, anyone in the Memphis TN area that knows a good independent mechanic that can work on a 96 dodge transmition?
   / Dodge Cummins Transmition #3
I can't help you with a mechanic in TN but there is a Dodge website that would likely be helpful. I can't remember the name, something like TD registry or some such. Hopefully you can find it on google or another TBNer will pop up with the URL.
On Ford truck related websites many people are going to very specific companies for replacement automatic transmissions. They have been very happy with the service from some/most of these copmanies. There is one company/guy, BTS, that is in TN somwhere. He is so busy he can be hard to get ahold of but people swear by his work. I think BTS stands for Brian's Transmission Shop. Sooo, maybe I DID help you find a mechanic in TN!
Good Luck!
Dan
   / Dodge Cummins Transmition #4
Hi meledward23. Here is the website of TDR, Turbo Diesel Register. I agree with dmccarty that you are likely to find this site very helpful.
12 Valve Engine and Transmission (1994 - 1998) - TDR Roundtable
The url I've given you is for the engine and transmission forum for 2nd gen CTD's. It is only one of many on this site. I think this is a most valuable resource for any owner of a Cummins Turbo Diesel. My truck is a '97 with a manual transmission. You don't say whether yours is a manual or automatic.
If a manual, you really need to pay attention to the possible solutions for the infamous " disappearing 5th gear" problem.
Good luck. I love my truck.
Mike
Thanks all. Looking at your links.
The truck is an automatic. It is one nice hauling machine. I really enjoy it despite that it is a dodge. And I believe it will keep running for quite some time just needs a little fixing to with a hammer.
   / Dodge Cummins Transmition #7
NIXON said:
Another good Dodge Diesel site is
www.dieseltruckresource.com/[/QUOTE...ke the TDR site its free... good luck Brian
   / Dodge Cummins Transmition #9
How many miles on it? 11 yrs old it's probably out of warranty :mad:
Good luck.
   / Dodge Cummins Transmition #10
Don't be too quick to replace or rebuild that transmission. I had mine rebuilt at 160k miles and added a new torque converter. The thing was slipping so bad when cold that I could not climb my driveway's gentle hill . It worked well after the rebuild so I thought nothing more about it.
At 300k, it started to do the same thing again, so I took it into the same shop that rebuilt it the first time. They said it needed another rebuild, but the shop had changed owners and I didn't trust the guy.
The truck acted like a nightmare. It would not shift or not go into overdrive and slip like crazy. I thought a couple of times it was going to fall out of the truck because it shook and shuddered so bad.
After checking all the websites, the only things I found were the TPS and a special electrical shielding that would keep noise out of the thottle position sensor (TPS) circuit. So I replaced the TPS and cleaned the battery terminals. That didn't help much.
Then I started reading about the Power Control Module (PCM) and how it was the computer that controlled the shifting. I read that many of the later models of truck (not '96s like ours) had a reflash and cured the transmission problem.
Hmm...the PCM is really a computer...Hmm...The lights started to come on in my head. I decided to do what I'd do to my PC if it started to really act up. I needed a cold reboot. To perform this, I completely disconnected both battery terminals so there is no power (like turning off a PC). Only with the PCM, you need to do it for several hours (like overnight) because it retains the program for short time disconnects.
The next morning, I got up and reconnected the terminals to the battery and my transmission suddenly started working like a new one. It shifts perfectly and has continued to work for 50k miles. What I needed was a PCM "reboot."
This might not be your problem, but it is sure cheap and easy to check. Make sure you take the opportunity to clean your cables really well while they are disconnected. Take off all the accessory and ground connections and clean them too so you have perfect electrical connections when you reconnect after letting it sit overnight.
If this doesn't fix it, then continue looking for a transmission shop or a new transmission. My guess is that you might be pleasantly surprised.
CUSHMAN HAULER PRO GAS GOLF CART (A54756)
CUSHMAN HAULER PRO...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
1675 (A54756)
1675 (A54756)
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
