Do You Like Your Asphalt Driveway.??
   / Do You Like Your Asphalt Driveway.?? #1
JDGreenGrass
Veteran Member
Maine
John Deere 770
I am getting sick of tracking gravel into the house. Thinking about splurging and having it done with asphalt.
Any pro's and con's to this.
We get a lot of snow so my tractor would be on it quite often. And what about summer....is it safe to travel on it with the tractor or does this "emboss" the asphalt.??
Feedback please.......
   / Do You Like Your Asphalt Driveway.?? #2
Have you looked at asphalt roads? They don't last. I would start at house and go out from there in concrete to the point that I could afford. Next year alittle more. etc.
   / Do You Like Your Asphalt Driveway.?? #3
I switched to crushed asphalt instead of the splurge to rolled roadway. No more dust, noise, migration or cost. Still have some weeds to deal with. Triox solves that.
My neighbor went for the asphalt. A deliver truck smooshed tire tracks into it. Its already cracked and had to be resealed. Yes the preparation is what makes a difference. He can't walk on it with bare feet. Even the dogs know better.
   / Do You Like Your Asphalt Driveway.?? #4
The tractor won't do any damage to the asphalt (if it is good asphalt, it will be hard).
It for sure solves the problem of tracking dirt (not just into the house, but the garage floor will be so much cleaner :) ).
The cons (I had gravel for 35 years, and asphalt for the last 10) are (IMO):
- Won't get the gravel worked up when plowing off snow, that gives good traction. The flip side, is the asphalt will attract more heat from the winter sun, and melt/dry the drive sooner than gravel.
- Expense after the asphalt is laid down, is getting it sealed every few years. And, after 10 years, it is now time to lay down another top coat because of shrinking and opening cracks. Also, a few areas that need to be ripped out and replaced.
- Crossing the drive with a new drain field line from the septic tank requires a section to be cut out and now replaced.
- Heavy trucks can sometimes be too much for the asphalt. With gravel, just didn't worry about them as much. The gas truck will make some "bird baths" the first couple years of new asphalt, from the brief setting while filling. Should have laid out some plywood pads for the truck to set on to avoid the bird baths.
- Asphalt is more expensive, even in the long run, but I like not having the dust and wet dust after a rain tracking into the garage (and yes, then into the house).
   / Do You Like Your Asphalt Driveway.?? #5
I have had gravel and asphalt ..If asphalt is put down on a solid base and you spray the edges to keep grass at bay you should be fine. After about 6 months seal the asphalt drive but after that you should not have to seal it again..our on our farm is 1/4 mile long by 14 ft. wide and I have sealed it once and it still looks great..Once a year I take the tractor with FEL and lay the bucket flat and gently scrape the grass from the edges and that is all it takes.
If you decide to stay with gravel then have some real wet crusher run delivered spread and rolled and then top it with some portland cement in power form and water it in..I have seen that work well. Also as another poster mentioned you can use ground up asphalt...if you can find a road crew that is grinding an old asphalt road prior to resurfacing it ...sometimes you can get it dumped on your driveway for free and then all you have to do is spread it and roll it out..
Nothing is perfect in an un-perfect world.
I guess I'll weigh my options.
Thanks.
In a perfect world I would lay brick. I love that look. $$$$$$.!!!!!
   / Do You Like Your Asphalt Driveway.?? #7
You can asphalt, have it go out in 10-12 years and do it again for what concrete will cost. Also, eventually whatever you put down WILL crack. I would rather watch the asphalt crack than concrete. Easier to fill and seal.
Concrete wouldn't be my first choice.
Just for kicks...how deep would you lay the concrete.??
   / Do You Like Your Asphalt Driveway.?? #9
Either material will work just fine during its normal service life IF you do it properly. The trouble with asphalt is that folks go cheap and only put down 2" on top of a thin layer of gravel. It looks great at first and the contractor gets his money but then it falls apart since it is only a thin blanket of material. Similarly, but much less common, is cheapskate concrete driveways with limited subgrade work but the forms almost always get you a good 4" of concrete. Seems that the concrete workers have more pride in their product than the asphalt guys.
You can pave a driveway with asphalt that will last decades, or you can pave one that will last 2 years.
Having a heavy truck create bird baths indicates that the job wasn't done or designed for that load and will have a short life with even normal traffic.
   / Do You Like Your Asphalt Driveway.?? #10
Different climate areas may have different asphalt design. The north will have a softer asphalt that may take tire impressions on very hot days.
Asphalt starts deteriorating the day you lay it down. Concrete keeps getting harder.:D
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A54607)
2016 INTERNATIONAL...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
