Do you know? I need help
   / Do you know? I need help #1
Sterling94
hdc
Can anyone tell me if rims from a Massey 1500 series ( I assume from the pictures in the add it's from a 1500 series compact tractor, not the big 1970's 4wd 1500) will fit a new holland tc29? I have a '02 tc29 with very worn out turf tires. I'm wanting to replace with R4's. I know I need to change the rear rims but having a hard time finding them used. I found some new take off set of tires and rims on fast line off a MF 1500 series. The ad says 8 lug rear and 6 lug front. I can not find specs on the MF pilot hole size and lug spacing to see if it matches the NH Tc29.
Thanks in advance
   / Do you know? I need help #2
HELP!
A better description in your thread title of your problem may get more responses, something like "Massey 1500 rim PCD/lug spacing dimensions required. Post in general or Massey forum instead would also help I expect. YMMV.
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2019 Cat D6N LGP Dozer (RIDE AND DRIVE) (A50774)
2019 Cat D6N LGP...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
