Mowing Do you have enough tractor?
   / Do you have enough tractor? #1
MutzFarm
Texas
Kubota M62
This is off one of my older threads, but the question comes up how much tractor do I need? People sending messages and emails. So I thought I would bring it up again.
Again every application is different. This unit works surprisingly well on our small farm, but now that we have customers a little more under the hood would be nice.
Well I aint saying Im the smartest, but how much tractor do you need? Took my 2012 Mahindra 4wd 4025 with a 6ft shredder thru some brush that at times was 8ft tall.
   / Do you have enough tractor? #2
I hear that all the time... "I cut brush X feet tall"...... with my small tractor...
Truth is, thick/heavy grass takes more power than brush...especially if the brush is green.
SR
   / Do you have enough tractor? #3
Amen to that Sawyer. Last year during the spring growing season after I cut my hay I took the tractor around the fence line to clean up. Tractor had enough horsepower but the grass was so thick that I kept breaking shear bolts and I was running at full PTO speed.
   / Do you have enough tractor? #4
"but now that we have customers"
If time mowing can be issue I wouldn't consider less than 5 or 6 hp per foot of mower...if you HST you will also lose hp.
I agree. Tall weeds usually dont bog you down because there is no under growth and they are spread a pinch between each other and the tractor doesnt get hot as quick. Now a thick coastal grass field will bog me down a lot faster. The thick grass seems to accumulate more in the screen and radiator then the weeds and brush. When in thick grass and summer temperatures I have stopped as often as every 30 minutes to blow out the radiator.
I also agree with a minimum of 5hp per foot. We are looking for a bit more under the hood soon.
   / Do you have enough tractor? #6
well said. to me it's not just about the ratio of tractor HP to the size brush hog, it's also about the ability of the smaller cut's to handle the weight of the hog itself. it then becomes a safety and maneuverability issue. yes, each circumstance is different and the 5-6 pto hp to foot of hog doesn't always apply. personally, using a medium to heavy duty 6' hog on anything less than say 35 hp pto tractor is pushing the limit.
but i've been wrong many times before :)
   / Do you have enough tractor? #7
I run my 6' Woods Rotary cutter "mostly" with my "rated" 42pto hp farm tractor, truth is I'd be willing to bet it has a little bit more than it's rated.
It's air cooled diesel NEVER even get's close to over heating, no matter how thick the grass is, although it does get a good work out!
Same thing with my 30hp Deutz "farm" tractor, although it is a full load on it... BUT, I can't say the same for when I put the same Woods cutter, on my tinker toy 30hp CUT, in the same field/grass! It started to get too hot in no time at all...just plain too much load on the pto... (yes I checked the cooling system good)
Anyway, I now have a deal going to buy another tractor just like pictured above, except it's rated 50pto hp instead of 42.
We'll see if he accepts my trade/offer.
SR
   / Do you have enough tractor? #8
I run a 6' Howes behind my 2501. No, I don't have enough tractor. I mow the sides of our road and a small clearing in the trees. Nothing over 12" and sparse. The mower was a left over from my old mowing business.
   / Do you have enough tractor? #9
For our needs, we had too much tractor in our late 70's IH2500b. It was too big to take through the woods and too wide to take between the tree rows once they started growing, and too large to trailer home for the winter. So once the large tasks on our tree farm/rural playground were done, we downsized to our current PowerTrac PT425. It's perfect for cutting and maintaining walking trails in woods and fields, fits nicely between the plantation tree rows, and we could back it up into the bed of our full sized pickup until we switched to a Suburban and car hauler trailer.
I gotta find my video of my little PT425 with a 25hp gas Kohler engine pushing my 48" brush cutter through 14' tall soaking wet thistles... I couldn't push my body through them. I love the brush cutter out front.
Here's a very old grainy video from the early 2000's of it clearing 5' dry weeds from a field in the fall.
   / Do you have enough tractor? #10
I get by with my 27hp/24pto JD 3005, running a 5' brush hog. As stated earlier, brush is easier than grass, which bogs it down, more so with the typical dull blades. Cuts grass better with sharper blades... I touch them up once in a while.
I need a bigger tractor, for the weight, power, and lift ability. Don't get me wrong, the 3005 does well for what it is, but I ask alot of it.
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
71067 (A49346)
71067 (A49346)
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
New Holland 451 Sickle Bar Mower (A50515)
New Holland 451...
