Robert_in_NY
Super Member
- Joined
- Aug 1, 2001
- Messages
- 8,552
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I replaced the rear 16.9-30 tire on my TN65 last summer. Its filled with calcium and when the tire shop came out and replaced the tire they installed a new tube at the same time which it needed. They finish up and leave, by that night the tire was flat again. They come back out and remove the tube and it shows the valve stem seperated from the tube. The service guy said they have been having a lot of problems with these tubes. So I lost a few days as they had to get another tube and replace it. The tractor really didn't get used much from that point till now as it was the end of haying season and we didn't get any snow. This year I do all the tillage work with the tractor and everythings fine. Park the tractor in a field for a few days and its fine, bring it home and refuel it and its fine. Put it in the barn for a couple days and its fine. I even changed the hydraulic oil and filters without noticing any problems. When we go to use the tractor a couple days later its flat. Air it up and the air is blowing out almost as fast as its going in. I didn't find any nails or pieces of steel in the tire so I have to assume the tube failed around the valve stem again.
This happened Saturday at 12:30 so the tire shop was already closed. I could have used the tractor today but I didn't want to get nailed with a huge emergency repair bill. The tube is less then a year old and I'm really not happy losing time again as I have to believe the shop was using poor quality materials. Do tubes have any warranty or better question am I out of line to expect this to be repaired on their expense? I don't know how much calcium I have lost because of these two "new" tubes failing but I have to believe it is adding up. I don't know how much drained out in the barn but its parked outside now with the stem up and axle blocked up. I'm going to call the shop in the morning and discuss it with them. If they do find its not the tube failing again then I have no problems paying for the repair but I don't believe that is the case here.
