do they work? riding mower baggers
   / do they work? riding mower baggers #1
searcyfarms
Veteran Member
kingsville, mo
Farmall 560D - 706D German w/Cab - Volvo MC110 - 1944JD A - Deere 2038R - IH 5088
I am looking at getting something to collect grass clippings / mulch leaves in the fall and wondering if they work very well.
I see the power driven ones off the deck pulleys that drive an impeller of some sort i presume which i am sure would help but i was wondering if something like the little ones on a cub cadet or craftsman or deere work very well?
I could see moisture being an issue but outside of that just curious before i pull the trigger
   / do they work? riding mower baggers #2
I’ve had 3 different versions:
1 belt pto powered off a 10 hp garden tractor with vacuum tube running down to the deck fitting,
2 deck blade pulley powered blower pushing into attached carrier on rear of 20 hp garden tractor
3 and current, rear pto driven vacuum with tube to deck fitting on B3350 (33hp)
Each worked and each had progressively bigger vacuum tubes and would clog progressively less.
Short dry grass is the easiest to pick up and most any should work. Small sticks start the grass dam.
Wet grass or damp long grass will still plug my current, on occasion. I just slow down and let more air thru .
   / do they work? riding mower baggers #3
I have a bagger on my Deere LA 125. Great for leaves in the fall. Not so great on green grass clippings as it clogs up from time to time.
   / do they work? riding mower baggers #4
I've got a rear discharge deck and a tow-behind ground powered sweeper. It works great for grass clippings. It works great for uncut leaves, but fills up ridiculously fast. It works so-so for cut leaves, depending on if they are dry or have been rained on.
If I could, I'd buy a self-powered gas engine bagger and tow it behind my machine, but my machine is not conducive to that.
   / do they work? riding mower baggers #5
I used to have a Toro time cutter ZTR mower with the twin bags that worked very well UNLESS the grass/leaves were wet. Then I'd sometimes have the chute clog up.
   / do they work? riding mower baggers #6
I have a JD G100 ( no longer made ) riding mower. It has a side discharge collection bag setup. It would work just fine on a normal lawn, dry grass, frequently cut.
My "lawn" is field grass that I've mowed for 38 years now. It slowly filled in and looks like a normal lawn. However, the grass is course, very succulent and does not blow well. I've done away with the collection system and just chop it up until it mulches in.
i was thinking more about driving over after the clippings have dried a day or so - i have a big mower that i mow with but from time to time i would like to clean up the clippings and put on my garden and maybe leaves in the fall and i also need a lighter weight mower to mow areas that are WET and my CUT is too heavy for w/out making ruts - i was thinking about picking up an inexpensive craftsman or deere used for that kind of thing so they wouldnt have the power driving blower type just the chute that goes on at the deck exit.
   / do they work? riding mower baggers #8
If I get small windrows of clippings and let them sit for a day or two to dry out, they don't mow over well, and you can still see where they sat on the lawn in lines. Kinda like leaving a garden hose laying in the lawn. It takes a few days to go away. I think it's better to either mow over the lines one more time to spread them out, or bag them VS waiting a few days to mow over the clippings again. Just my personal preference.
   / do they work? riding mower baggers #9
i was thinking more about driving over after the clippings have dried a day or so....
Around here, we call that mowing the lawn again! :laughing:
We've had so much rain (frequency, not so much volume) this month that the grass needs mowing about every 3 days, but it's too wet to get on it. So I've been having to mow over the thing two and three times to get the clippings spread out if I don't use the tow-behind sweeper.
i have seen those sweepers with a rotary broom thing do those work just as well as a bagger type and trying to mow/blow - same here such a wet year its been more than challenging
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
1240 (A50490)
1240 (A50490)
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
Bus (A50323)
Bus (A50323)
