Tires Do RIMs and Tires come from Kubota?
   / Do RIMs and Tires come from Kubota? #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
I had mentioned in my review of my new B2320 that tires and RIMs mismatched brands.
I then later visited the dealer while it was closed and looked through all the tractors.
The tires and RIMs were like 4 brands and there was no consistency.
Some tractors would have all 4 match Rim and tires and another would not.
Two exact tractors next to each with same type of tires may have different brands. Or the reverse from front to back.
So I think tires and rims are handled seperately from the tractor.
I kinda wondered why it was no big deal to switch tires last minute because I thought they would have to swap them from another tractor or something.
But I think they stock tires and RIMs seperately and slap them on each tractor as they come in.
Not sure they come from Kubota but they have like 4 brands of RIMs.
Some dealer may exclusively use one brand than another dealer.
This probably makes sense because the tire types are probably very local specific.
   / Do RIMs and Tires come from Kubota? #2
Some tires are different because they are speed rated. This is so you do not experience blow outs when picking up speed to ram fixed objects. :D
   / Do RIMs and Tires come from Kubota? #3
I imagine Kubota out sources its tires and maybe its rims. I know most car makers do. I would suspect that most tractors are shipped with tires and rims, but maybe not mounted to the tractor. I would think that most tractors would have matching tires and rims, but at a large dealership, they may get mixed up.
   / Do RIMs and Tires come from Kubota? #4
My tractor came with Firestones on the back, Goodyears on the front.
   / Do RIMs and Tires come from Kubota? #5
I would agree with Mr. Dodge Man. Tractors never come with their wheels attached, so in a large shipment, you'd end up with crates of tractors over here, loaders over there, and tires over yonder in that box. When final assembly occurs at the dealership, they just grab the correct size and roll with it.
I don't think Kubota has a lot of control over it...it would depend on the ****-retentiveness of the assembly man at the dealership to ensure all the tires match manufacturers.
Personally, I'm glad that I have one of those dealerships with ****-retentive assembly guys AND maintenance guys. My tractor always purrs like a kitten and looks like gold whenever I get it back from the dealership. They've taken exceptional care of me and all my tires match.
Non-matching tires or rims from right to left would bother me to no end...I probably wouldn't accept the tractor that way. Not front to back, though.
It could also be that in some tire sizes, one manufacturer makes one (front) and not the other (back), requiring the use of different brands. Not Kubota's fault. Just another idea to consider.
I never said they mismatched left to right. All pairs of RIMs and Tires matched. It's only front to back that varied.
   / Do RIMs and Tires come from Kubota? #7
How can you tell that the front rims didn't match the rears? Was it the color? I think, in most cases, front and rear rims have very little in common other than being round and painted.
As mentioned, the brands of my tires are different but the type, R1, is the same. So no big deal. Obviously if the type of tire was mismatched front to rear that would not only be unacceptable but could possibly damage a 4wd tractor.
   / Do RIMs and Tires come from Kubota? #8
I bought a L2800 last year from a Rome GA dealer. I think they get the rims and tires locally. Had Titans on the rear. David............
OTR Wheel Engineering
   / Do RIMs and Tires come from Kubota? #9
I have the bar/turfs and the fronts and rears are different brands and styles. The front rims are distinctly different from the rears too. I suspect that since particular sizes are needed, they have to go to different makers for them. Makes no difference to me.
You can tell different brand rims after you look at bunch. Some have a logo stamped on them. Some have a common model number scheme etc. Some have the brand name stamped on them. Some I think are actually made by kubota.
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2016 PETERBILT 389 SLEEPER (A52472)
2016 PETERBILT 389...
