Do L3450s have bad engines?
/ Do L3450s have bad engines? #1
SPYDERLK
Super Star Member
VA
JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
After several years and 2000hrs on an L2550 we upgraded my wifes tractor to an L3450 with 1700 hrs bought on eBay. The 3450 engine did not sound good like the one on the 2550 always had thru years of rough treatment. We wanted the greater power on the familiar platform, while retaining the 2 speed PTO dropped from later models, so we bought the 3450 with plans to put the engine right - it sounded like a wrist pin or piston slap, and there was excessive blowby at the breather. The tractor performed acceptably for the 126hrs we used it before putting it in the shop.
It turned out the cylinders were ovaled and tapered - #4 especially. Nothing else seemed amiss. Nevertheless, along with all liners and pistons, the bearings and valves were replaced. The rebuilt engine does not have blowby but still has the same knock/tap quality that put it in the shop.:confused: The tap is a good bit quieter, but knowing what this sound turned into in 1700 hrs has me real worried. Does anyone know of problems with the 3450 engines?
Thanks,
larry
/ Do L3450s have bad engines? #2
Never heard of chronic engine weakness in specific Kubota models. But there are engines that get damaged by their owners (or prior owners). If running on old contaminated oil, and/or running hot from a fouled radiator screen, the rings/sleeves/piston skirts/bearing shells can give it up. Some engines sound different than others depending on how the fuel is injected. And diesels make a racket anyway. Maybe it's really ok now and all it needs is proper maintenance.
As always, prompt cheerful refund if info is bogus. Take care, Dick B
/ Do L3450s have bad engines? #3
I have had a L3010, L3130, have a B7800 and L4240 Kubotas and they all have had the same noise that sounds like 2or3 marbles in a glass jar.jumping around. The best I can tell it's coming from more to the rear then from the front. I ask the dealer's service manager if they new what it was and he said they didn't, but he new what I was talking about. I also had a Johndeere 950 and it didn't do it.
Does anyone else hear the same or I'm going nuts? All the Tractors ran great. Maybe you are hearing what I am?
Leejohn said:
I have had a L3010, L3130, have a B7800 and L4240 Kubotas and they all have had the same noise that sounds like 2or3 marbles in a glass jar.jumping around. [[[The best I can tell it's coming from more to the rear then from the front.]]] I ask the dealer's service manager if they new what it was and he said they didn't, but he new what I was talking about. I also had a Johndeere 950 and it didn't do it.
Does anyone else hear the same or I'm going nuts? All the Tractors ran great. [[[Maybe you are hearing what I am?]]]
[Maybe.....?] What Im worried about is that the noise in the completely rebuilt L3450 engine sounds just like the horrible sound it made before being rebuilt -- only quieter. The degeneration to the loud hammering didnt happen under my watch so I had been expecting that some abuse caused it and a rebuild would totally fix it. The way it sounds now I can just imagine it happening again.:( My L2550 has been beat to crap with marginal preventive maintenance and sounds sweet. - I guess Im looking for knowledge of some trouble area in this particular engine model that must be correct, or it beats its cylinder walls up.
larry
/ Do L3450s have bad engines? #5
SPYDERLK said:
........It turned out the cylinders were ovaled and tapered - #4 especially. Nothing else seemed amiss. Nevertheless, along with all liners and pistons, the bearings and valves were replaced......
In your latest post you mention "hammering" - which makes me think about the crank, not the pistons. Piston slap is a somewhat lighter knocking noise - but a crank that's loose in its main bearings (especially at the flywheel end) can sound like a heavy hammer. Do you know if the crank journals were measured when the engine was worked? Could the crank be egged too - so there's still too much clearance in the main bearing shells? One way to get an indication is to replace the oil pressure switch with a gage and watch how it acts with a warm engine. Bad bearings tend to show changes in oil pressure going from power on (pulling) to power off (compression braking).
/ Do L3450s have bad engines? #6
I can't say we've notice one Kubota engine being better than any other. They are all simply great. That being said, there may have been a reason that tractor was sold, who knows what the history was, or why it was on ebay. Alot of stuff that goes there has questionable backgrounds.
Thanks for the idea. It was not a heavy knock and also seemed to be up top. Imagine Mighty Mouse inside with an 8 oz ball pein hammer - LOUD violent tapping. I will specifically ask the mechanic about the condition of the main journals. Im expecting he was thorough. He didnt do the liner/piston fitting tho and Im curious as to the clearance set up, esp at the rear. - Also, the liners are quite thin. Im assuming theyre not wet. Wondering whether the bores that they fit in may have been misshapen.
larry
I hear ya. After my experience w the 2550 thats what I thot. I figured I would set the 3450 right and have a Kubota engine. The problem is it still sounds wrong in the same way it did before a total rebuild. Just lighter tapping - same exact throttle, speed, related characteristic. It even still taps as it coasts to a stop. Could the block be damaged in some way that is not apparent even with total disassembly?
larry
/ Do L3450s have bad engines? #9
Larry,
You need a control. Any chance you can listen to another 3450 and decide for yourself if it's just typical noise or something that needs tending to?
-Jim
/ Do L3450s have bad engines? #10
larry
Whether the mechanic miked the journals, or used plastiguage, it requires
more work. Esp the latter measurement, which requires one more assembly/
dissassembly. He prob did not do it.
Anyway, I have not had a Kub diesel apart yet, and I am curious if they
have wet liners. All my Kubota engines have been great (even on ex-rentals),
so I have not had to rebuild one yet. One thing changed around 2000: it
seems all the engines got quieter.
Baby Grand said:
Larry,
-Jim
Love to. Ill keep my eye out for one everywhere I go. Any readers in Orange, Culpeper, Fredericksburg, Charlottesville?
larry
/ Do L3450s have bad engines? #12
Larry,
The Grand L 50 used a direct injection design combustion chamber which has more rattle or combustion noise than the indirect combustion chamber design.
I am not trying to talk you out of doing some checking but if the noise is similar to what was present before the overhaul, likely it is normal.
Cam ground pistons (oval when cold, round when hot - for different expansion rate at pin boss) were used on some series of engines a number of years ago, but they are not doing this presently.
As for sleeves, the bores are all "parent metal", "en bloc" or linerless - the early 2 cylinders (L200/210) used dry sleeves but the rest have not used sleeves.
Now you know...
/ Do L3450s have bad engines? #13
A failing injector will also make a horrible hammer racket as one cylinder is getting either to much fuel or a real poor spray pattern from the injector tip. I would look into having the injectors check by a certified diesel injector/pump rebuilder for proper spray pattern and "pop" pressure. The old B7100 I am looking at has pretty good blow by out the breather tube, but runs well and will last me for years running like that. Eventualy I will tear it down and rering it ect. But even running in that condition, it sounds just like the other "chery" B7100 with less that 800 hours on it, while the one I may be getting has 2100 hours on it. Cheers Mike
Yankee Clipper said:
Larry,
Now you know...
The L3450 definitely has sleeves. Difficult to see and not everybody knows about them. Fortunately we ran into somebody that knew that engine was sleeved and argued us into taking a closer look. Even the Kubota dealer didnt know!:eek: How in the world can that fact escape a Kubota dealer.
larry
botamike said:
A failing injector will also make a horrible hammer racket as one cylinder is getting either to much fuel or a real poor spray pattern from the injector tip. I would look into having the injectors check by a certified diesel injector/pump rebuilder for proper spray pattern and "pop" pressure. Cheers Mike
Thanks. That sounds like a good move. Ill plan on that. The only thing that doesnt fit with that is the noise is still present with no fuel during turnoff coast down. Its not so bad now. I just dont want it to get worse!
larry
/ Do L3450s have bad engines? #16
The rear cylinders usually get the preheated water from the front cylinder, so they usually wear a bit more. Both cylinder and piston. I've seen this in numerous engines. Gas and diesel. The rear cylinder piston run hotter than the front cylinders. That with DI engine, more wear, more nosie in rear cylinders. My 1972 International BD154 engine is direct injection, and is much noiser that the 2005 New Holland TC48. Also it has much more wear due to high hours.
