Do I need to????
   / Do I need to???? #1
badels
Casper, WY
JD 3520 w/Cab
Hey guys, I have a question about, and concerns, with a new front blade I bought for my tractor. The tractor is new and the blade is used. Both are John Deere. Do I need to worry about introducing the old hydraulic fluid into the system of my new tractor? My concern is the fluid looks just a little milky. Is there any way I can flush the system on the blade before I hook it up? I'll probably put new hoses on any way, but what about the fluid left in the cylinders. Thanks
Brad
   / Do I need to???? #2
Remove any hoses and try pushing in the rod and drain, and then pull the rod out and drain.
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
Peterbilt (A51692)
Peterbilt (A51692)
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
